Datasheet Texas Instruments LMK61E2BAA-SIAR — Даташит
| Серия | LMK61E2 |
| Модель | LMK61E2BAA-SIAR |
Полностью программируемый генератор со сверхнизким джиттером, встроенная EEPROM, +/-50ppm, 8-QFM, от -40 до 85
LMK61E2 Ultra-Low Jitter Programmable Oscillator With Internal EEPROM datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 3 фев 2017
Купить LMK61E2BAA-SIAR на РадиоЛоцман.Цены — от 925 до 3 700 ₽10 предложений от 10 поставщиков IC OSC CLOCK 1GHZ 8QFM. Clock Oscillator IC 400MHz, 900MHz, 1GHz 8-QFM (7x5). Clock/Timing - Programmable Timers and Oscillators | |||
| LMK61E2BAA-SIAR Texas Instruments | 1 286 ₽ | ||
| LMK61E2BAA-SIAR Texas Instruments | 1 923 ₽ | ||
| LMK61E2BAA-SIAR Texas Instruments | 3 700 ₽ | ||
| LMK61E2BAA-SIAR Texas Instruments | по запросу | ||
| Pin | 8 | 8 |
| Package Type | SIA | SIA |
| Industry STD Term | QFM | QFM |
| JEDEC Code | R-PSIP-N | R-PSIP-N |
| Package QTY | 2500 | 2500 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | LMK61E2 | BAA |
| Width (мм) | 5 | 5 |
| Length (мм) | 7 | 7 |
| Thickness (мм) | .8 | .8 |
| Pitch (мм) | 1.85 | 1.85 |
| Max Height (мм) | 1.15 | 1.15 |
| Additional Features | 7x5mm |
| Jitter | 0.1 ps |
| Output Frequency(Max) | 1000 МГц |
| Output Level | HCSL,LVDS,LVPECL |
| Pin/Package | 8QFM |
| Rating | Catalog |
| Special Features | Programmable with EEPROM |
| Stability | 50 ppm |
| VCC Core | 3.3 В |
- Evaluation Modules & Boards: LMK61E2EVM
LMK61E2EVM Ultra-Low-Jitter Programmable Oscillator Evaluation Module
- Time Domain Jitter Measurement Consideration for Low-Noise OscillatorsPDF, 321 Кб, Файл опубликован: 5 окт 2015
Phase Noise and Jitter are important metrics that describe the quality of a low-noise oscillator. Jitter is a time-domain representation of the timing accuracy of a signal and Phase Noise is the frequency domain representation of noise spectrum around the carrier tone. Equipment for measuring jitter in time-domain, such as real-time oscilloscopes, excel in their ability to directly measure period - Clocking for Medical Ultrasound SystemsPDF, 1.8 Мб, Файл опубликован: 20 сен 2017
- Frequency Margining Using TI's High Performance Programmable OscillatorsPDF, 871 Кб, Файл опубликован: 2 окт 2015
Crystal oscillators and/or multiple output clock generators are critical in today’s high performance consumer, computing, and communications systems. Deciding an optimal clock rate for the system can sometimes require several rounds of prototyping and validation. Clock Generators and Oscillator ICs - with the right hooks to margin synthesized clocks - can help to streamline the overall product dev - Vibration and Shock Sensitivity: A Comparative Study of OscillatorsPDF, 2.8 Мб, Файл опубликован: 11 янв 2017
When designing a system that incorporates a clock oscillator, the vibration sensitivity of the oscillatordevice is a specification that is easily overlooked. Sensitivity to vibration can have a detrimental impact onthe overall system performance. Since crystal oscillators fundamentally rely on the vibration andmechanical resonance of a piezoelectric material, external disturbances can couple
Серия: LMK61E2 (6)
- LMK61E2-SIAR LMK61E2-SIAT LMK61E2BAA-SIAR LMK61E2BAA-SIAT LMK61E2BBA-SIAR LMK61E2BBA-SIAT
- Semiconductors > Clock and Timing > Clock Oscillators
LMK61E2BAASIAR, LMK61E2BAA SIAR
