Datasheet Texas Instruments LMP90080MHX/NOPB — Даташит
СерияLMP90080
МодельLMP90080MHX/NOPB
Многоканальный маломощный 16-битный датчик AFE с непрерывной фоновой калибровкой 28-HTSSOP от -40 до 125
LMP9007x/LMP90080 Sensor AFE System: Multi-Channel, Low-Power 16-Bit Sensor AFE With True Continuous Background Calibration datasheet
PDF, 2.0 Мб, Версия: H, Файл опубликован: 22 янв 2016
Pin2828
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаMHLMP90080
Width (мм)4.44.4
Length (мм)9.79.7
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
# Input Channels7
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.85 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesExcitation Current Sources (iDACs),PGA
InterfaceSPI
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Power Consumption(Typ)1.2 mW
Reference ModeExt
Разрешение16 Bits
Sample Rate (max)215SPS SPS
Sample Rate(Max)0.000215 MSPS
  • Evaluation Modules & Boards: LMP90100EB
    LMP90100 Sensor AFE Evaluation Board
  • Evaluation Modules & Boards: SPIO-4
    Sensor AFE Digital Controller Board
  • AN-2180 LMP90100 True Continuous Background Calibration (Rev. B)
    PDF, 105 Кб, Версия: B, Файл опубликован: 1 май 2013
    To achieve the desired low offset and gain errors over time and temperature, the Texas Instruments LMP90100 employs a technique called true continuous background calibration. This technique essentially eliminates the device’s gain and offset errors at all gains and output data rates. This application report discusses how this technique works as well as summarize the numerous background calibration
  • Microcontroller Firmware Considerations for the National LMP90100 Sensor AFE (Rev. A)
    PDF, 111 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application report provides guidance to the firmware designer on how to communicate with the LMP90100 across the SPI interface as implemented on this device.
  • AN-2217 MSP430 Interface to LMP90100 Code Library (Rev. A)
    PDF, 4.1 Мб, Версия: A, Файл опубликован: 1 май 2013
    This application report describes different ways to interface and use the TI LMP90100 devices with an MSP430. The accompanying software contains a function library allowing quick prototyping of sensor AFE setup and control. The software provided in this library is a starting point for developers wanting to get the most out of the MSP430 and the LMP90100 Sensor AFE devices.It shows how to communi
  • AN-2265 LMP90100/098(24-bit) and LMP90080/078 (16-bit) 4 Wire RTD (Rev. C)
    PDF, 42 Кб, Версия: C, Файл опубликован: 25 июн 2015
    This application report discusses the use of the LMP90100/LMP90098 (24 bit) and LMP90080/LMP90078 (16 bit) sensor analog front ends (AFE’s) together with a resistive temperature device (RTD) using a 4-wire configuration.
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • A Unique Approach to Developing Sensor Signal Path Solutions
    PDF, 7.2 Мб, Файл опубликован: 3 авг 2011
Серия: LMP90080 (3)
На английском языке: Datasheet Texas Instruments LMP90080MHX/NOPB
