Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LMP91000SD/NOPB — Даташит
СерияLMP91000
МодельLMP91000SD/NOPB
Конфигурируемый потенциостат AFE для маломощных приложений химического зондирования 14-WSON от -40 до 85
LMP91000 Sensor AFE System: Configurable AFE Potentiostat for Low-Power Chemical-Sensing Applications datasheet
PDF, 1.3 Мб, Версия: I, Файл опубликован: 31 дек 2014
Pin14
Package TypeNHL
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
МаркировкаL91000
Width (мм)4
Length (мм)4
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)2.7 В
ApplicationsGas Sensing (Electrochemical)
Integrated FeaturesTransimpedance Amplifier,Temp. Sensor
InterfaceSerial I2C
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Ток потребления0.01 мА
  • Evaluation Modules & Boards: LMP91000EVM
    LMP91000EVM Evaluation Module
  • Evaluation Modules & Boards: GASSENSOREVM
    Gas Sensor Platform with Bluetooth Low Energy Evaluation Module
  • Evaluation Modules & Boards: SPIO-4
    Sensor AFE Digital Controller Board
  • AN-2230 MSP430 Interface to LMP91000 Code Library (Rev. C)
    PDF, 29.3 Мб, Версия: C, Файл опубликован: 1 май 2013
    The MSP430в„ў is an ideal microcontroller solution for low-cost, low-power precision sensor applications because it consumes very little power. The LMP91000 is a rogrammable analog front end (AFE) for use in micro-power electrochemical sensing applications. It provides a complete signal path solution between a sensor and a microcontroller that generates an output voltage proportional to the ce
Серия: LMP91000 (3)
  • Semiconductors > Sensing Products > Gas/Chemical Sensing AFEs
На английском языке: Datasheet Texas Instruments LMP91000SD/NOPB
