Datasheet Texas Instruments LMP91050MMX/NOPB — Даташит
СерияLMP91050
МодельLMP91050MMX/NOPB
Конфигурируемый AFE для приложений недисперсионного инфракрасного (NDIR) измерения 10-VSSOP от -40 до 105
LMP91050 Configurable AFE for Nondispersive Infrared (NDIR) Sensing Applications datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 30 сен 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY3500
МаркировкаAN8A
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
ApplicationsNDIR Gas Sensing
Integrated FeaturesPGA
InterfaceSerial SPI
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Ток потребления3.7 мА
  • Evaluation Modules & Boards: LMP91050SDEVAL
    Sensor AFE Eval Platform for NDIR Applications
  • Evaluation Modules & Boards: SPIO-4
    Sensor AFE Digital Controller Board
  • AN-2260 MSP430 Interface to LMP91050 Code Library (Rev. A)
    PDF, 6.1 Мб, Версия: A, Файл опубликован: 1 май 2013
    The MSP430в„ў is an ideal microcontroller solution for low-cost, low-power precision sensor applicationsbecause it consumes very little power. The LMP91050 is a programmable integrated analog front end (AFE) for thermopile sensors, as typically used in nondispersive infrared (NDIR) applications. This library provides functions to facilitate the interfacing of any MSP430 device to a LMP91050.
  • LMP91051 NDIR CO2 Gas Detection System
    PDF, 1.2 Мб, Файл опубликован: 9 май 2013
    This Application Note begins with an introduction to nondispersive infrared (NDIR) gas sensing. The useof the LMP91051 NDIR AFE and MSP430F55XX microcontroller to make accurate CO2 NDIR gasmeasurements is examined. Performance, power, speed, and size are compared against the traditionaldiscrete op amp system.
Серия: LMP91050 (3)
  • Semiconductors > Sensing Products > Gas/Chemical Sensing AFEs
На английском языке: Datasheet Texas Instruments LMP91050MMX/NOPB
