Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LMR14206 — Даташит
СерияLMR14206
SIMPLE SWITCHERВ® 4.5V to 42V, 0.6A Step-Down DC/DC Switching Regulator in SOT-23 Package
LMR14206 SIMPLE SWITCHER 42Vin, 0.6A Step-Dwn V-Reg in SOT-23 datasheet
PDF, 835 Кб, Версия: D, Файл опубликован: 30 сен 2015
LMR14206XMK/NOPBLMR14206XMKE/NOPBLMR14206XMKX/NOPB
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаДа
N123
Pin666
Package TypeDDCDDCDDC
Industry STD TermSOT-23-THINSOT-23-THINSOT-23-THIN
Package QTY10002503000
CarrierLARGE T&RSMALL T&RLARGE T&R
МаркировкаSJ2BSJ2BSJ2B
Width (мм)1.61.61.6
Length (мм)2.92.92.9
Thickness (мм).87.87.87
Pitch (мм).95.95.95
Max Height (мм)1.11.11.1
Parameters / ModelsLMR14206XMK/NOPB
LMR14206XMK/NOPB
LMR14206XMKE/NOPB
LMR14206XMKE/NOPB
LMR14206XMKX/NOPB
LMR14206XMKX/NOPB
Control ModeCurrent ModeCurrent ModeCurrent Mode
Duty Cycle(Max), %878787
Iout(Max), A0.60.60.6
Iq(Typ), мА1.31.31.3
Рабочий диапазон температур, Cот -40 до 125от -40 до 125от -40 до 125
Package GroupSOT-23-THINSOT-23-THINSOT-23-THIN
RatingCatalogCatalogCatalog
Regulated Outputs111
Special FeaturesEnableEnableEnable
Switching Frequency(Max), kHz150015001500
Switching Frequency(Min), kHz950950950
ТипConverterConverterConverter
Vin(Max), В424242
Vin(Min), В4.54.54.5
Vout(Max), В343434
Vout(Min), В0.7650.7650.765
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Designing Low Cost Flyback Power Supply Using Boost Converter (TPS61165) for HF
    PDF, 4.2 Мб, Файл опубликован: 17 апр 2014
    TPS61165, LMR14206, TPS5401, AMC1100, TLV1117I-33, TLV1117I-50 Designing low cost flyback supply using boost converter for HF Inverter
  • Semiconductors> Power Management> Non-isolated DC/DC Switching Regulator> Step-Down (Buck)> Buck Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LMR14206
