Datasheet Texas Instruments LMT70 — Даташит
СерияLMT70
В±0.1В°C Precision Analog Temperature Sensor
LMT70, LMT70A В±0.05В°C Precision Analog Temperature Sensor, RTD and Precision NTC Thermistor IC datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 11 май 2015
LMT70YFQRLMT70YFQT
Доступность образцов у производителяНетДа
LMT70YFQRLMT70YFQT
N12
Pin44
Package TypeYFQYFQ
Industry STD TermDSBGADSBGA
JEDEC CodeS-XBGA-NS-XBGA-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
Thickness (мм).42.42
Pitch (мм).4.4
Max Height (мм).675.675
Parameters / ModelsLMT70YFQR
LMT70YFQR
LMT70YFQT
LMT70YFQT
InterfaceAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C0.360.36
Рабочий диапазон температур, Cот -55 до 150от -55 до 150
Output Impedance, Ohm8080
Package GroupDSBGADSBGA
Package Size: mm2:W x L, PKGSee datasheet (DSBGA)See datasheet (DSBGA)
RatingCatalogCatalog
Sensor Gain, mV/Deg C-5.19-5.19
Supply Current(Max), uA1212
Supply Voltage(Max), В5.55.5
Supply Voltage(Min), В22
LMT70YFQRLMT70YFQT
RoHSСовместимСовместим
  • Wearable Temp-Sensing Layout Considerations Optimized for Thermal Response (Rev. B)
    PDF, 3.6 Мб, Версия: B, Файл опубликован: 23 окт 2018
    This applicationnotediscussesthermalresponseconsiderationsfor IC temperaturesensorsin measuringskin temperaturefor wearableapplicationssuchas fitnessbandsand medicaldevices.It will specificallyfocuson twodevices—the LMT70andthe TMP117temperaturesensors—overthe humanbodytemperaturerange.Thisinformationcan be appliedhoweverto ot
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT70 (2)
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT70
