Datasheet Texas Instruments LMT70A — Даташит
СерияLMT70A
В±0.1В°C Matching Accuracy Precision Analog Temperature Sensor
LMT70, LMT70A В±0.05В°C Precision Analog Temperature Sensor, RTD and Precision NTC Thermistor IC datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 11 май 2015
52 предложений от 17 поставщиков
SENSOR ANALOG -55C-150C 4DSBGA. Temperature Sensor Analog, Local -55°C ~ 150°C 5.194mV/°C 4-DSBGA (0.81x0.81). Temperature Sensors - Analog and Digital Output...
Рутоника
LMT70AYFQR
81 ₽
ICdarom.ru
LMT70AYFQR
от 102 ₽
LMT70AYFQR
168 ₽
LMT70AYFQR
174 ₽
LMT70AYFQRLMT70AYFQT
Доступность образцов у производителяДаНет
N12
Pin44
Package TypeYFQYFQ
Industry STD TermDSBGADSBGA
JEDEC CodeS-XBGA-NS-XBGA-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
Thickness (мм).42.42
Pitch (мм).4.4
Max Height (мм).675.675
Parameters / ModelsLMT70AYFQR
LMT70AYFQR
LMT70AYFQT
LMT70AYFQT
InterfaceAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C0.360.36
Рабочий диапазон температур, Cот -55 до 150от -55 до 150
Output Impedance, Ohm8080
Package GroupDSBGADSBGA
Package Size: mm2:W x L, PKGSee datasheet (DSBGA)See datasheet (DSBGA)
RatingCatalogCatalog
Sensor Gain, mV/Deg C-5.19-5.19
Supply Current(Max), uA1212
Supply Voltage(Max), В5.55.5
Supply Voltage(Min), В22
RoHSСовместимСовместим
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT70A (2)
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT70A
