Datasheet Texas Instruments LMT88 — Даташит
СерияLMT88
Датчик температуры с аналоговым выходом 2,4 В, 10 мкА
LMT88 2.4-V, 10-µA, SC-70 Temperature Sensor datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 31 янв 2015
LMT88DCKRLMT88DCKT
Доступность образцов у производителяДаДа
LMT88DCKRLMT88DCKT
N12
Pin55
Package TypeDCKDCK
Industry STD TermSOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаT9CT9C
Width (мм)1.251.25
Length (мм)22
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)1.11.1
Parameters / ModelsLMT88DCKR
LMT88DCKR
LMT88DCKT
LMT88DCKT
InterfaceAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C55
Рабочий диапазон температур, Cот -55 до 130от -55 до 130
Output Impedance, Ohm160160
Package GroupSC70SC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingCatalogCatalog
Sensor Gain, mV/Deg C-11.77-11.77
Special FeaturesIndustry standard pinoutIndustry standard pinout
Supply Current(Max), uA77
Supply Voltage(Max), В5.55.5
Supply Voltage(Min), В2.42.4
LMT88DCKRLMT88DCKT
RoHSСовместимСовместим
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT88 (2)
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT88
