Оптопары и оптореле Megawin
Datasheet Texas Instruments LMT90 — Даташит
СерияLMT90
Positive +10.0mV/В°C Gain Analog Output Temperature Sensor
LMT90 SOT-23 Single-Supply Centigrade Temperature Sensor datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 29 сен 2015
LMT90DBZRLMT90DBZT
Доступность образцов у производителяНетДа
LMT90DBZRLMT90DBZT
N12
Pin33
Package TypeDBZDBZ
Industry STD TermSOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаT8CT8C
Width (мм)1.31.3
Length (мм)2.922.92
Thickness (мм)11
Pitch (мм).96.96
Max Height (мм)1.221.22
Parameters / ModelsLMT90DBZR
LMT90DBZR
LMT90DBZT
LMT90DBZT
InterfaceAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C44
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Output Impedance, Ohm20002000
Package GroupSOT-23SOT-23
Package Size: mm2:W x L, PKG3SOT-23: 4 mm2: 1.3 x 2.92(SOT-23)3SOT-23: 4 mm2: 1.3 x 2.92(SOT-23)
RatingCatalogCatalog
Sensor Gain, mV/Deg C1010
Special FeaturesIndustry standard pinoutIndustry standard pinout
Supply Current(Max), uA130130
Supply Voltage(Max), В1010
Supply Voltage(Min), В4.54.5
LMT90DBZRLMT90DBZT
RoHSСовместимСовместим
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT90 (2)
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT90
