Datasheet Texas Instruments LMV225SDX/NOPB — Даташит
СерияLMV225
МодельLMV225SDX/NOPB
Детектор радиочастотной мощности для CDMA и WCDMA в микро-SMD 6-WSON от -40 до 85
LMV225/LMV226/LMV228 RF Power Detector for CDMA and WCDMA datasheet
PDF, 2.3 Мб, Версия: L, Файл опубликован: 22 мар 2013
Pin6
Package TypeNGF
Industry STD TermWSON
JEDEC CodeR-PDSO-N
Package QTY4500
МаркировкаA90
Width (мм)2.2
Length (мм)2.5
Thickness (мм).8
Max Height (мм)8
Точность1 дБ
ApplicationCDMA,EDGE,GPRS,GSM,TDMA,WCDMA
Количество каналов1 Channels
DetectorLogarithmic Amp
Detector Power Range-30dBm to 0dBm
Dynamic Range30 дБ
Modulation IndependentNo
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
RF Frequency450-2000 МГц
ShutdownYes
Ток потребления4.8 мА
Supply Max5 Volt
Supply Min2.7 Volt
TransferLinear in dB
  • Evaluation Modules & Boards: LMV225SDEVAL
    Evaluation Board for the LMV225 LLP
  • Evaluation Modules & Boards: LMV225TLEVAL
    Evaluation Board for the LMV225 microSMD
  • Use of LMV225 Linear-In-dB RF Pwr Detector In CDMA2000 (Rev. A)
    PDF, 357 Кб, Версия: A, Файл опубликован: 30 апр 2013
    This application report discusses the use of LMV225 Linear-In-dB RF Power Detector In a CDMA2000 1Xand EV_DO mobile station and access terminal.
  • Reduce DC Pwr Consump in CDMA RF Pwr Amps Thru the LMV225 & Eff Switcher (Rev. A)
    PDF, 105 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report presents a simple power tracking technique for efficiency enhancement in CDMA RF power amplifiers. This technique involves the use of a linear-in-dB RF power detector and a DC-DC converter switch. This enhancement scheme switches the DC supply voltage, VCC, of an RF power amplifier into two different levels through a DC-DC converter. Texas Instruments RF power detector LMV2
  • Semiconductors > RF & Microwave > RF Power Detector
На английском языке: Datasheet Texas Instruments LMV225SDX/NOPB
