Datasheet Texas Instruments LMV228TL/NOPB — Даташит
СерияLMV228
МодельLMV228TL/NOPB
Детектор радиочастотной мощности для CDMA и WCDMA в микро-SMD 4-DSBGA от -40 до 85
LMV225/LMV226/LMV228 RF Power Detector for CDMA and WCDMA datasheet
PDF, 2.3 Мб, Версия: L, Файл опубликован: 22 мар 2013
Pin4
Package TypeYZR
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
Width (мм)1.3
Length (мм)1.5
Thickness (мм).675
Pitch (мм).5
Max Height (мм).675
Точность1 дБ
ApplicationCDMA,EDGE,GPRS,GSM,TDMA,WCDMA
Количество каналов1 Channels
DetectorLogarithmic Amp
Detector Power Range-15dBm to 15dBm
Dynamic Range30 дБ
Modulation IndependentNo
Package GroupDSBGA
RF Frequency450-2000 МГц
ShutdownYes
Ток потребления4.9 мА
Supply Max5 Volt
Supply Min2.7 Volt
TransferLinear in dB
  • Evaluation Modules & Boards: LMV228TLEVAL
    Evaluation Board for the LMV228 microSMD RF Detector
  • Evaluation Modules & Boards: LMV228SDEVAL
  • AN-1375 Linear-In-dB RF Power Detector In W-CDMA User Equipment (Rev. A)
    PDF, 924 Кб, Версия: A, Файл опубликован: 30 апр 2013
    Since most of the deployed W-CDMA networks use FDD mode only and the W-CDMA FDD has fastclosed-loop power control in both uplink and downlink, hardware implementation for RF power detection indownlink from user equipment to base station is needed in order to meet the required air interfacestandard. This application report suggests application subsystem circuits for use in closed-loop power
Серия: LMV228 (4)
  • Semiconductors > RF & Microwave > RF Power Detector
На английском языке: Datasheet Texas Instruments LMV228TL/NOPB
