Datasheet Texas Instruments LMZ10500SILR — Даташит
СерияLMZ10500
МодельLMZ10500SILR
Нано-модуль высокой плотности от 2,7 В до 5,5 В, 650 мА 8-uSiP от -40 до 125
LMZ10500 650-mA SIMPLE SWITCHERВ® Nano Module With 5.5-V Maximum Input Voltage datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 16 фев 2015
28 предложений от 12 поставщиков
DC DC CONVERTER 0.6-3.6V 2W. Non-Isolated PoL Module DC DC Converter 1 Output 0.6 ~ 3.6V 650mA 2.7V - 5.5V Input....
LMZ10500SILR
от 46 ₽
Эиком
LMZ10500SILR
418 ₽
LMZ10500SILR
727GS
LMZ10500SILR
Pin888888
Package TypeSILSILSILSILSILSIL
Package QTY300030003000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&R
Маркировка9821DH0500 9821 DH0500500TXN5000EC
Iout(Max)0.65 A
Iq(Typ)6.5 мА
Package TypeMicroSiP (LGA)
Regulated Outputs1
Soft StartFixed
Special FeaturesEMI Tested,Enable
Switching Frequency(Max)2250 kHz
Switching Frequency(Min)1750 kHz
Switching Frequency(Typ)2000 kHz
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)3.6 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: LMZ10500SILEVM
    LMZ10500 650mA SIMPLE SWITCHERВ® Nano Module Evaluation Board
  • AN-2168 LMZ10501 and LMZ10500 SIMPLE SWITCHER Nano Module EMI Performance (Rev. A)
    PDF, 403 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The LMZ10501 and LMZ10500 nano modules offer excellent EMI performance. The evaluation board withthe default components complies with the CISPR 22 Class B radiated emissions standard. Adding twosmall 0.1ОјF 0805 input capacitors results in CISPR 25 Class 5 radiated emissions standard compliance.The addition of a small LC filter (1ОјH and 1ОјF) to the input of the default evaluation board result
  • AN-2169 LMZ10501 and LMZ10500 SIMPLE SWITCHER Nano Module (Rev. A)
    PDF, 298 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The LMZ10501 and LMZ10500 SIMPLE SWITCHER nano modules are easy-to-use DC-DC solutionsoptimized for space-constrained applications. The LMZ10501 is capable of driving up to 1A load withexcellent power conversion efficiency, line and load regulation. The LMZ10500 is a 650mA version moduleand is pin-to-pin compatible with the LMZ10501.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
Серия: LMZ10500 (2)
  • Semiconductors > Power Management > Power Modules > Non-Isolated Module > Step-Down (Buck) Module
На английском языке: Datasheet Texas Instruments LMZ10500SILR
