Datasheet Texas Instruments LMZ10500SILT — Даташит
Серия | LMZ10500 |
Модель | LMZ10500SILT |
Нано-модуль высокой плотности от 2,7 В до 5,5 В, 650 мА 8-uSiP от -40 до 125
LMZ10500 650-mA SIMPLE SWITCHERВ® Nano Module With 5.5-V Maximum Input Voltage datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 16 фев 2015
![]() 36 предложений от 13 поставщиков DC DC CONVERTER 0.6-3.6V 2W. Non-Isolated PoL Module DC DC Converter 1 Output 0.6 ~ 3.6V 650mA 2.7V - 5.5V Input.... | |||
LMZ10500SILT Texas Instruments | 150 ₽ | ||
LMZ10500SILT Texas Instruments | 189 ₽ | ||
LMZ10500SILT Texas Instruments | от 513 ₽ | ||
LMZ10500SILT Texas Instruments | 18 765 ₽ |
Pin | 8 | 8 | 8 | 8 | 8 | 8 |
Package Type | SIL | SIL | SIL | SIL | SIL | SIL |
Package QTY | 250 | 250 | 250 | 250 | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R | SMALL T&R | SMALL T&R | SMALL T&R | SMALL T&R |
Маркировка | 9821 | 500 | DH | TXN5000EC | 0500 | 0500 9821 DH |
Iout(Max) | 0.65 A |
Iq(Typ) | 6.5 мА |
Package Type | MicroSiP (LGA) |
Regulated Outputs | 1 |
Soft Start | Fixed |
Special Features | EMI Tested,Enable |
Switching Frequency(Max) | 2250 kHz |
Switching Frequency(Min) | 1750 kHz |
Switching Frequency(Typ) | 2000 kHz |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
Vout(Max) | 3.6 В |
Vout(Min) | 0.6 В |
- Evaluation Modules & Boards: LMZ10500SILEVM
LMZ10500 650mA SIMPLE SWITCHERВ® Nano Module Evaluation Board
- AN-2168 LMZ10501 and LMZ10500 SIMPLE SWITCHER Nano Module EMI Performance (Rev. A)PDF, 403 Кб, Версия: A, Файл опубликован: 23 апр 2013
The LMZ10501 and LMZ10500 nano modules offer excellent EMI performance. The evaluation board withthe default components complies with the CISPR 22 Class B radiated emissions standard. Adding twosmall 0.1ОјF 0805 input capacitors results in CISPR 25 Class 5 radiated emissions standard compliance.The addition of a small LC filter (1ОјH and 1ОјF) to the input of the default evaluation board result - AN-2169 LMZ10501 and LMZ10500 SIMPLE SWITCHER Nano Module (Rev. A)PDF, 298 Кб, Версия: A, Файл опубликован: 23 апр 2013
The LMZ10501 and LMZ10500 SIMPLE SWITCHER nano modules are easy-to-use DC-DC solutionsoptimized for space-constrained applications. The LMZ10501 is capable of driving up to 1A load withexcellent power conversion efficiency, line and load regulation. The LMZ10500 is a 650mA version moduleand is pin-to-pin compatible with the LMZ10501. - Understanding and Applying Current-Mode Control TheoryPDF, 409 Кб, Файл опубликован: 19 авг 2007
- AN-643 EMI/RFI Board Design (Rev. B)PDF, 742 Кб, Версия: B, Файл опубликован: 3 май 2004
Application Note 643 EMI/RFI Board Design - AN-1889 How to Measure the Loop Transfer Function of Power Supplies (Rev. A)PDF, 2.7 Мб, Версия: A, Файл опубликован: 23 апр 2013
Серия: LMZ10500 (2)
- LMZ10500SILR LMZ10500SILT
- Semiconductors > Power Management > Power Modules > Non-Isolated Module > Step-Down (Buck) Module
