Datasheet Texas Instruments LMZ31704 — Даташит
СерияLMZ31704
SIMPLE SWITCHERВ® 2.95V to 17V, 4A Power Module with Current Sharing
LMZ31704 4-A SIMPLE SWITCHERВ® Module, 2.95-V to 17-V Input and Current Sharing datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 7 июн 2017
LMZ31704RVQRLMZ31704RVQT
Доступность образцов у производителяНетДа
N12
Pin4242
Package TypeRVQRVQ
Industry STD TermB3QFNB3QFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY500250
CarrierLARGE T&RSMALL T&R
Маркировка5402054020
Width (мм)1010
Length (мм)1010
Thickness (мм)4.34.3
Pitch (мм).8.8
Max Height (мм)4.44.4
Parameters / ModelsLMZ31704RVQR
LMZ31704RVQR
LMZ31704RVQT
LMZ31704RVQT
Iout(Max), A44
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package Size: mm2:W x L, PKG42B3QFN: 100 mm2: 10 x 10(B3QFN)42B3QFN: 100 mm2: 10 x 10(B3QFN)
Package TypeQFNQFN
Regulated Outputs11
Soft StartAdjustableAdjustable
Special FeaturesCurrent Sharing,EMI Tested,Frequency Synchronization,Power Good,Remote Sense,Tracking,Light Load EfficiencyCurrent Sharing,EMI Tested,Frequency Synchronization,Power Good,Remote Sense,Tracking,Light Load Efficiency
Switching Frequency(Max), kHz12001200
Switching Frequency(Min), kHz200200
Switching Frequency(Typ), kHz10001000
Vin(Max), В1717
Vin(Min), В2.952.95
Vout(Max), В5.55.5
Vout(Min), В0.60.6
RoHSНе совместимНе совместим
  • Using LMZ31710 for Higher Output Voltages
    PDF, 95 Кб, Файл опубликован: 9 ноя 2015
    The LMZ31710 power module has been designed and characterized for operation at output voltages from0.6 V to 5.5 V. However, several applications require higher voltages than the standard point-of-loadvoltages that the LMZ31710 is designed for. Following the guidance in this application note, theLMZ31710 can be used for output voltages up to 9.5 V. All data included in this application note h
  • LMZ31710, LMZ31707, LMZ31704 Parallel
    PDF, 217 Кб, Файл опубликован: 2 июл 2013
    The LMZ31710 is a 2.95-V to 17-V input, 10-A output, integrated power solution which integrates the PWM controller, power MOSFETs, inductor and passives in a low-profile, QFN package. For applications requiring greater than 10 A, it is possible to parallel up to six LMZ31710 devices by following the recommendations in this paper.
  • Power Module MSL Ratings
    PDF, 137 Кб, Файл опубликован: 20 янв 2017
    All semiconductor devices, including power modules that have a moisture sensitivity level (MSL) rating and a peak reflow classification, which provides needed information when manufacturing with the device. This application report helps to explain these ratings.
  • Powering LMZ3 SIMPLE SWITCHER Power Modules From 3.3 V
    PDF, 38 Кб, Файл опубликован: 2 июл 2013
    LMZ31503 Powering LMZ3 SIMPLE SWITCHERВ® Power Modules from 3.3V
  • Adjusting LMZ3 Output Voltage with LM10010/1
    PDF, 87 Кб, Файл опубликован: 11 фев 2014
    ThisapplicationnoteoutlinesthemethodstopairanLMZ3powermodulewithanLM10010/1VIDvoltageprogrammertoadjusttheoutputvoltage.TheLMZ3powermoduleisaneasy-to-useintegratedpowersolutionwhichcombinesaDC/DCconverterwithpowerMOSFETs,ashieldedinductor,andpassivecomponentsintoalowprofileQFNpackage,whilest
  • Working With QFN Power Modules (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 8 июн 2017
    TexasInstrumentsQuadFlatpackNo-lead(QFN)powermodulesallowfor boardminiaturization,and holdseveraladvantagesoverotherpowermodulepackages.The QFNpackageshavehigherpowerdensity,asmallerroutingarea,improvedthermalperformance,and improvedelectricalparasitics.Additionally,theabsenceof externalleadseliminatesbent-leadconc
  • Soldering Requirements for BQFN Packages (Rev. B)
    PDF, 737 Кб, Версия: B, Файл опубликован: 8 июн 2017
    This documentoutlinesthe solderingrequirementsfor the TPS84and LMZ3devicefamilies
  • Uninterruptible Synchronization Clock Circuit
    PDF, 74 Кб, Файл опубликован: 22 ноя 2013
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: LMZ31704 (2)
  • Semiconductors> Power Management> Power Modules> Non-Isolated Module> Step-Down (Buck) Module
На английском языке: Datasheet Texas Instruments LMZ31704
