Datasheet Texas Instruments LMZ31710RVQR — Даташит
СерияLMZ31710
МодельLMZ31710RVQR
Модуль питания SIMPLE SWITCHER® от 2,95 до 17 В, 10 А с разделением тока 42-B3QFN от -40 до 85
LMZ31710 10-A SIMPLE SWITCHERВ® Power Module 2.95-V to 17-V Input Current Sharing datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 7 июн 2017
Pin4242
Package TypeRVQRVQ
Industry STD TermB3QFNB3QFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY500500
CarrierLARGE T&RLARGE T&R
МаркировкаLMZ3171054020
Width (мм)1010
Length (мм)1010
Thickness (мм)4.34.3
Pitch (мм).8.8
Max Height (мм)4.44.4
Iout(Max)10 A
Package Size: mm2:W x L42B3QFN: 100 mm2: 10 x 10(B3QFN) PKG
Package TypeQFN
Regulated Outputs1
Soft StartAdjustable
Special FeaturesCurrent Sharing,EMI Tested,Frequency Synchronization,Power Good,Remote Sense,Tracking,Light Load Efficiency
Switching Frequency(Max)1200 kHz
Switching Frequency(Min)200 kHz
Switching Frequency(Typ)1000 kHz
Vin(Max)17 В
Vin(Min)2.95 В
Vout(Max)5.5 В
Vout(Min)0.6 В
RoHSНе совместим
  • Evaluation Modules & Boards: LMZ31710EVM-001
    SIMPLE SWITCHERВ® 10A Power Module Evaluation Board
  • Evaluation Modules & Boards: LMZ31710X2EVM
    LMZ31710 Parallel Board
  • LMZ31710, LMZ31707, LMZ31704 Parallel
    PDF, 217 Кб, Файл опубликован: 2 июл 2013
    The LMZ31710 is a 2.95-V to 17-V input, 10-A output, integrated power solution which integrates the PWM controller, power MOSFETs, inductor and passives in a low-profile, QFN package. For applications requiring greater than 10 A, it is possible to parallel up to six LMZ31710 devices by following the recommendations in this paper.
  • Using LMZ31710 for Higher Output Voltages
    PDF, 95 Кб, Файл опубликован: 9 ноя 2015
    The LMZ31710 power module has been designed and characterized for operation at output voltages from0.6 V to 5.5 V. However, several applications require higher voltages than the standard point-of-loadvoltages that the LMZ31710 is designed for. Following the guidance in this application note, theLMZ31710 can be used for output voltages up to 9.5 V. All data included in this application note h
  • Power Module MSL Ratings
    PDF, 137 Кб, Файл опубликован: 20 янв 2017
    All semiconductor devices, including power modules that have a moisture sensitivity level (MSL) rating and a peak reflow classification, which provides needed information when manufacturing with the device. This application report helps to explain these ratings.
  • Powering LMZ3 SIMPLE SWITCHER Power Modules From 3.3 V
    PDF, 38 Кб, Файл опубликован: 2 июл 2013
    LMZ31503 Powering LMZ3 SIMPLE SWITCHERВ® Power Modules from 3.3V
  • Adjusting LMZ3 Output Voltage with LM10010/1
    PDF, 87 Кб, Файл опубликован: 11 фев 2014
    ThisapplicationnoteoutlinesthemethodstopairanLMZ3powermodulewithanLM10010/1VIDvoltageprogrammertoadjusttheoutputvoltage.TheLMZ3powermoduleisaneasy-to-useintegratedpowersolutionwhichcombinesaDC/DCconverterwithpowerMOSFETs,ashieldedinductor,andpassivecomponentsintoalowprofileQFNpackage,whilest
  • Working With QFN Power Modules (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 8 июн 2017
    TexasInstrumentsQuadFlatpackNo-lead(QFN)powermodulesallowfor boardminiaturization,and holdseveraladvantagesoverotherpowermodulepackages.The QFNpackageshavehigherpowerdensity,asmallerroutingarea,improvedthermalperformance,and improvedelectricalparasitics.Additionally,theabsenceof externalleadseliminatesbent-leadconc
  • Soldering Requirements for BQFN Packages (Rev. B)
    PDF, 737 Кб, Версия: B, Файл опубликован: 8 июн 2017
    This documentoutlinesthe solderingrequirementsfor the TPS84and LMZ3devicefamilies
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: LMZ31710 (2)
  • Semiconductors > Power Management > Power Modules > Non-Isolated Module > Step-Down (Buck) Module
На английском языке: Datasheet Texas Instruments LMZ31710RVQR
