Datasheet Texas Instruments LMZ35003RKGT — Даташит
СерияLMZ35003
МодельLMZ35003RKGT
Модуль питания SIMPLE SWITCHER® от 7 до 50 В, 2,5 А, широкий разъем питания в малом корпусе 41-B1QFN от -40 до 85
LMZ35003 2.5-A SIMPLE SWITCHERВ® Power Module with 7-V to 50-V Input QFN Package datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 7 июн 2017
Pin4141
Package TypeRKGRKG
Industry STD TermB1QFNB1QFN
JEDEC CodeR-PQFP-NR-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка54260LMZ35003
Width (мм)99
Length (мм)1111
Thickness (мм)2.82.8
Pitch (мм).9.9
Max Height (мм)2.92.9
Iout(Max)2.5 A
Package Size: mm2:W x L41B1QFN: 99 mm2: 9 x 11(B1QFN) PKG
Package TypeQFN
Regulated Outputs1
Soft StartAdjustable
Special FeaturesEMI Tested,Enable,Frequency Synchronization,Power Good,Remote Sense,Tracking
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)300 kHz
Switching Frequency(Typ)400 kHz
Vin(Max)50 В
Vin(Min)7 В
Vout(Max)15 В
Vout(Min)2.5 В
RoHSНе совместим
  • Evaluation Modules & Boards: LMZ35003EVM-001
    SIMPLE SWITCHERВ® 2.5A Power Module Evaluation Board
  • LMZ35003 Protects Against 60-V Line Transients
    PDF, 27 Кб, Файл опубликован: 18 июн 2015
    The LMZ35003, wide input voltage, 2.5-A Simple SwitcherВ® power module is designed for typicaloperating input voltages of 7 V to 50 V. However, with a 65-V absolute maximum input voltage rating, theLMZ35003 can be used in applications where the input voltage exceeds 50 V during line transients. The 7V to 50 V operating input voltage range of the LMZ35003 is recommended for the best performanc
  • LMZ35003 Parallel Operation
    PDF, 218 Кб, Файл опубликован: 28 май 2014
    The LMZ35003 is a 7-V to 50-V input, 2.5-A output, integrated power module which integrates a DC/DCconverter, shielded inductor and passives in a low-profile, QFN package. For applications requiring greaterthan 2.5 A, it is possible to parallel multiple LMZ35003 devices by following the recommendations in thispaper.
  • Power Module MSL Ratings
    PDF, 137 Кб, Файл опубликован: 20 янв 2017
    All semiconductor devices, including power modules that have a moisture sensitivity level (MSL) rating and a peak reflow classification, which provides needed information when manufacturing with the device. This application report helps to explain these ratings.
  • Working With QFN Power Modules (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 8 июн 2017
    TexasInstrumentsQuadFlatpackNo-lead(QFN)powermodulesallowfor boardminiaturization,and holdseveraladvantagesoverotherpowermodulepackages.The QFNpackageshavehigherpowerdensity,asmallerroutingarea,improvedthermalperformance,and improvedelectricalparasitics.Additionally,theabsenceof externalleadseliminatesbent-leadconc
  • Soldering Requirements for BQFN Packages (Rev. B)
    PDF, 737 Кб, Версия: B, Файл опубликован: 8 июн 2017
    This documentoutlinesthe solderingrequirementsfor the TPS84and LMZ3devicefamilies
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: LMZ35003 (2)
  • Semiconductors > Power Management > Power Modules > Non-Isolated Module > Step-Down (Buck) Module
На английском языке: Datasheet Texas Instruments LMZ35003RKGT
