Datasheet Texas Instruments LMZ35003 — Даташит
СерияLMZ35003
SIMPLE SWITCHERВ® 7V to 50V, 2.5A Wide Vin Power Module in Small Package
LMZ35003 2.5-A SIMPLE SWITCHERВ® Power Module with 7-V to 50-V Input QFN Package datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 7 июн 2017
LMZ35003RKGRLMZ35003RKGT
Доступность образцов у производителяДаНет
N12
Pin4141
Package TypeRKGRKG
Industry STD TermB1QFNB1QFN
JEDEC CodeR-PQFP-NR-PQFP-N
Package QTY500250
CarrierLARGE T&RSMALL T&R
Маркировка5426054260
Width (мм)99
Length (мм)1111
Thickness (мм)2.82.8
Pitch (мм).9.9
Max Height (мм)2.92.9
Parameters / ModelsLMZ35003RKGR
LMZ35003RKGR
LMZ35003RKGT
LMZ35003RKGT
Iout(Max), A2.52.5
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package Size: mm2:W x L, PKG41B1QFN: 99 mm2: 9 x 11(B1QFN)41B1QFN: 99 mm2: 9 x 11(B1QFN)
Package TypeQFNQFN
Regulated Outputs11
Soft StartAdjustableAdjustable
Special FeaturesEMI Tested,Enable,Frequency Synchronization,Power Good,Remote Sense,TrackingEMI Tested,Enable,Frequency Synchronization,Power Good,Remote Sense,Tracking
Switching Frequency(Max), kHz10001000
Switching Frequency(Min), kHz300300
Switching Frequency(Typ), kHz400400
Vin(Max), В5050
Vin(Min), В77
Vout(Max), В1515
Vout(Min), В2.52.5
RoHSНе совместимНе совместим
  • LMZ35003 Protects Against 60-V Line Transients
    PDF, 27 Кб, Файл опубликован: 18 июн 2015
    The LMZ35003, wide input voltage, 2.5-A Simple SwitcherВ® power module is designed for typicaloperating input voltages of 7 V to 50 V. However, with a 65-V absolute maximum input voltage rating, theLMZ35003 can be used in applications where the input voltage exceeds 50 V during line transients. The 7V to 50 V operating input voltage range of the LMZ35003 is recommended for the best performanc
  • LMZ35003 Parallel Operation
    PDF, 218 Кб, Файл опубликован: 28 май 2014
    The LMZ35003 is a 7-V to 50-V input, 2.5-A output, integrated power module which integrates a DC/DCconverter, shielded inductor and passives in a low-profile, QFN package. For applications requiring greaterthan 2.5 A, it is possible to parallel multiple LMZ35003 devices by following the recommendations in thispaper.
  • Power Module MSL Ratings
    PDF, 137 Кб, Файл опубликован: 20 янв 2017
    All semiconductor devices, including power modules that have a moisture sensitivity level (MSL) rating and a peak reflow classification, which provides needed information when manufacturing with the device. This application report helps to explain these ratings.
  • Working With QFN Power Modules (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 8 июн 2017
    TexasInstrumentsQuadFlatpackNo-lead(QFN)powermodulesallowfor boardminiaturization,and holdseveraladvantagesoverotherpowermodulepackages.The QFNpackageshavehigherpowerdensity,asmallerroutingarea,improvedthermalperformance,and improvedelectricalparasitics.Additionally,theabsenceof externalleadseliminatesbent-leadconc
  • Soldering Requirements for BQFN Packages (Rev. B)
    PDF, 737 Кб, Версия: B, Файл опубликован: 8 июн 2017
    This documentoutlinesthe solderingrequirementsfor the TPS84and LMZ3devicefamilies
  • Uninterruptible Synchronization Clock Circuit
    PDF, 74 Кб, Файл опубликован: 22 ноя 2013
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: LMZ35003 (2)
  • Semiconductors> Power Management> Power Modules> Non-Isolated Module> Step-Down (Buck) Module
На английском языке: Datasheet Texas Instruments LMZ35003
