Datasheet Texas Instruments LP2951-50-Q1 — Даташит
СерияLP2951-50-Q1
Автомобильный LDO с одним выходом, 100 мА, фиксированный, широкий диапазон напряжения
Datasheet
TSP
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors> Power Management> Linear Regulator (LDO)> Single Channel LDO
На английском языке: Datasheet Texas Instruments LP2951-50-Q1
