Datasheet Texas Instruments LP2995MRX/NOPB — Даташит
СерияLP2995
МодельLP2995MRX/NOPB
Регулятор терминации DDR 8-SO PowerPAD от 0 до 125
LP2995 DDR Termination Regulator datasheet
PDF, 1.5 Мб, Версия: M, Файл опубликован: 19 мар 2013
Package TypeDDA
Industry STD TermHSOIC
Package QTY2500
МаркировкаLP2995
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Control ModeN/A
DDR Memory TypeDDR
Iout VTT(Max)1.5 A
Iq(Typ)0.25 мА
Рабочий диапазон температурот 0 до 125 C
OutputVREF,VTT
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Regulator TypeLinear Regulator
Special FeaturesN/A
Vin Bias(Max)5.5 В
Vin Bias(Min)2.2 В
Vin(Max)5.5 В
Vin(Min)2.2 В
Vout VTT(Min)1.25 В
  • Evaluation Modules & Boards: LP2995M-EVAL
  • Evaluation Modules & Boards: LP2995LQEVAL
  • Limiting DDR Termination Regulators’ Inrush Current
    PDF, 772 Кб, Файл опубликован: 23 авг 2016
    The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
  • DDR-SDRAM Termination Simplified Using A Linear Regulator
    PDF, 120 Кб, Файл опубликован: 23 июл 2002
  • AN-1254 DDR-SDRAM Termination Simplified Using a Linear Regulator (Rev. A)
    PDF, 66 Кб, Версия: A, Файл опубликован: 6 май 2013
    This applications report describes the use and benefits of the LP2995 for DDR-DRAM Termination.
  • Semiconductors > Power Management > DDR Memory Power Solutions
На английском языке: Datasheet Texas Instruments LP2995MRX/NOPB
