Datasheet Texas Instruments LP2996MRX/NOPB — Даташит
СерияLP2996-N
МодельLP2996MRX/NOPB
Стабилизатор нагрузки DDR 1,5 А с контактом отключения 8-SO PowerPAD 0–125
LP2996-N, LP2996A DDR Termination Regulator datasheet
PDF, 1.7 Мб, Версия: K, Файл опубликован: 23 дек 2016
Package TypeDDA
Industry STD TermHSOIC
Package QTY2500
МаркировкаLP2996
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Control ModeN/A
DDR Memory TypeDDR,DDR2
Iout VTT(Max)1.5 A
Iq(Typ)0.32 мА
Рабочий диапазон температурот 0 до 125 C
OutputVREF,VTT
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Regulator TypeLinear Regulator
Special FeaturesShutdown Pin for S3
Vin Bias(Max)5.5 В
Vin Bias(Min)2.2 В
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout VTT(Min)0.9 В
  • Evaluation Modules & Boards: LP2996LQEVAL
  • Evaluation Modules & Boards: LP2996MREVAL
  • Limiting DDR Termination Regulators’ Inrush Current
    PDF, 772 Кб, Файл опубликован: 23 авг 2016
    The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
  • Semiconductors > Power Management > DDR Memory Power Solutions
На английском языке: Datasheet Texas Instruments LP2996MRX/NOPB
