Datasheet Texas Instruments LP2996AMRE/NOPB — Даташит
| Серия | LP2996A |
| Модель | LP2996AMRE/NOPB |
Стабилизатор нагрузки DDR 1,5 А с контактом отключения 8-SO PowerPAD 0–125
LP2996A DDR Termination Regulator datasheet
PDF, 2.5 Мб, Файл опубликован: 27 июн 2014
Купить LP2996AMRE/NOPB на РадиоЛоцман.Цены — от 36 до 222 ₽16 предложений от 10 поставщиков IC DDR TERMINATION REG 8SOPWRPAD. DDR Terminator PMIC 8-SO PowerPad. PMIC - Power Management - Specialized | |||
| LP2996AMRE/NOPB Texas Instruments | от 36 ₽ | ||
| LP2996AMRE/NOPB Texas Instruments | 65 ₽ | ||
| LP2996AMRE/NOPB Texas Instruments | 156 ₽ | ||
| LP2996AMRE/NOPB Texas Instruments | по запросу | ||
| Pin | 8 | 8 |
| Package Type | DDA | DDA |
| Industry STD Term | HSOIC | HSOIC |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 250 | 250 |
| Carrier | SMALL T&R | SMALL T&R |
| Маркировка | AMR | LP2996 |
| Width (мм) | 3.9 | 3.9 |
| Length (мм) | 4.89 | 4.89 |
| Thickness (мм) | 1.48 | 1.48 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 1.7 | 1.7 |
| Control Mode | N/A |
| DDR Memory Type | DDR,DDR2,DDR3,DDR3L |
| Iout VTT(Max) | 1.5 A |
| Iq(Typ) | 0.32 мА |
| Рабочий диапазон температур | от 0 до 125 C |
| Output | VREF,VTT |
| Package Group | SO PowerPAD |
| Package Size: mm2:W x L | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG |
| Rating | Catalog |
| Regulator Type | Linear Regulator |
| Special Features | Shutdown Pin for S3 |
| Vin Bias(Max) | 5.5 В |
| Vin Bias(Min) | 2.2 В |
| Vin(Max) | 5.5 В |
| Vin(Min) | 1.35 В |
| Vout VTT(Min) | 0.677 В |
- Evaluation Modules & Boards: LP2998EVAL
Evaluation Board for the LP2998
- Limiting DDR Termination Regulators’ Inrush CurrentPDF, 772 Кб, Файл опубликован: 23 авг 2016
The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
Серия: LP2996A (3)
- LP2996AMR/NOPB LP2996AMRE/NOPB LP2996AMRX/NOPB
- Semiconductors > Power Management > DDR Memory Power Solutions
