Datasheet Texas Instruments LP2997MR/NOPB — Даташит
СерияLP2997
МодельLP2997MR/NOPB
Регулятор терминации DDR-II 8-SO PowerPAD от 0 до 125
LP2997 DDR-II Termination Regulator datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 4 апр 2013
Pin88
Package TypeDDADDA
Industry STD TermHSOICHSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаMRL2997
Width (мм)3.93.9
Length (мм)4.894.89
Thickness (мм)1.481.48
Pitch (мм)1.271.27
Max Height (мм)1.71.7
Control ModeN/A
DDR Memory TypeDDR2
Iout VTT(Max)0.5 A
Iq(Typ)0.32 мА
Рабочий диапазон температурот 0 до 125 C
OutputVREF,VTT
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Regulator TypeLinear Regulator
Special FeaturesShutdown Pin for S3
Vin Bias(Max)5.5 В
Vin Bias(Min)2.2 В
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout VTT(Min)0.9 В
  • Limiting DDR Termination Regulators’ Inrush Current
    PDF, 772 Кб, Файл опубликован: 23 авг 2016
    The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
  • AN-1254 DDR-SDRAM Termination Simplified Using a Linear Regulator (Rev. A)
    PDF, 66 Кб, Версия: A, Файл опубликован: 6 май 2013
    This applications report describes the use and benefits of the LP2995 for DDR-DRAM Termination.
  • Semiconductors > Power Management > DDR Memory Power Solutions
На английском языке: Datasheet Texas Instruments LP2997MR/NOPB
