Datasheet Texas Instruments LP2998MRE/NOPB — Даташит
СерияLP2998
МодельLP2998MRE/NOPB
Стабилизатор нагрузки DDR 1,5 А с контактом отключения 8-SO PowerPAD от -40 до 125
LP2998/LP2998-Q1 DDR Termination Regulator datasheet
PDF, 2.6 Мб, Версия: K, Файл опубликован: 20 авг 2014
Pin88
Package TypeDDADDA
Industry STD TermHSOICHSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаMRLP2998
Width (мм)3.93.9
Length (мм)4.894.89
Thickness (мм)1.481.48
Pitch (мм)1.271.27
Max Height (мм)1.71.7
Control ModeN/A
DDR Memory TypeDDR,DDR2,DDR3,DDR3L
Iout VTT(Max)1.5 A
Iq(Typ)0.32 мА
OutputVREF,VTT
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Regulator TypeLinear Regulator
Special FeaturesShutdown Pin for S3
Vin Bias(Max)5.5 В
Vin Bias(Min)2.2 В
Vin(Max)5.5 В
Vin(Min)1.35 В
Vout VTT(Min)0.677 В
  • Evaluation Modules & Boards: LP2998EVAL
    Evaluation Board for the LP2998
  • Limiting DDR Termination Regulators’ Inrush Current
    PDF, 772 Кб, Файл опубликован: 23 авг 2016
    The output voltage of DDR termination regulators tends to rise quickly after their VDDQ line is enabled. Most DDR terminators are specifically designed for fast start-up. They also require bulky output capacitors for a stable output voltage. This often results in a significant inrush current from DDR terminator voltage supply to charge the output capacitors and to provide curre
  • AN-1254 DDR-SDRAM Termination Simplified Using a Linear Regulator (Rev. A)
    PDF, 66 Кб, Версия: A, Файл опубликован: 6 май 2013
    This applications report describes the use and benefits of the LP2995 for DDR-DRAM Termination.
  • Semiconductors > Power Management > DDR Memory Power Solutions
На английском языке: Datasheet Texas Instruments LP2998MRE/NOPB
