Datasheet Texas Instruments LP3470IM5X-2.83/NOPB — Даташит
| Серия | LP3470 |
| Модель | LP3470IM5X-2.83/NOPB |
Active low Reset IC with Programmable Delay and 1% Reset ThresholdВ 5-SOT-23
LP3470 Voltage Supervisor With Programmable Delay and 1% Reset Threshold datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 27 апр 2016
Купить LP3470IM5X-2.83/NOPB на РадиоЛоцман.Цены — от 25 до 214 ₽12 предложений от 12 поставщиков IC SUPERVISOR 1 CHANNEL SOT23-5. Supervisor Open Drain or Open Collector 1 Channel SOT-23-5. PMIC - Supervisors | |||
| LP3470IM5X-2.83/NOPB Texas Instruments | 43 ₽ | ||
| LP3470IM5X-2.83/NOPB Texas Instruments | 84 ₽ | ||
| LP3470IM5X-2.83/NOPB Texas Instruments | 120 ₽ | ||
| LP3470IM5X-2.83/NOPB Texas Instruments | 214 ₽ | ||
| Pin | 5 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | D39C |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 1 |
| Iq(Typ) | 16 uA |
| Monitored Voltage 1 (typ)(Nom) | 3,3.3,4.4,5 В |
| Monitored Voltage 2 (typ)(Nom) | N/A В |
| Рабочий диапазон температур | от -20 до 85,-40 до 85 C |
| Output Driver Type / Reset Output | Active-low,Open-drain |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rating | Catalog |
| Reset Threshold Accuracy | 1 % |
| Threshold Voltage 1(Typ) | 2.63,2.75,2.83,2.93,3.08,3.65,4,4.38,4.63,4.8 В |
| Threshold Voltage 2 (typ)(Typ) | N/A В |
| Time Delay | Programmable ms |
| VCC(Max) | 5 В |
| VCC(Min) | 0.5 В |
| Watchdog Timer WDI | None sec |
- Maximizing Start-Up Loads w/LM3352 Regulated Buck-Boost Switched Cap Converter (Rev. B)PDF, 76 Кб, Версия: B, Файл опубликован: 6 май 2013
This application report discusses maximizing start-up loads with the LM3352 regulated buck/boost switched capacitor converter.
Серия: LP3470 (38)
- LP3470IM5-2.63/NOPB LP3470IM5-2.75/NOPB LP3470IM5-2.83/NOPB LP3470IM5-2.93 LP3470IM5-2.93/NOPB LP3470IM5-3.08 LP3470IM5-3.08/NOPB LP3470IM5-3.65/NOPB LP3470IM5-4.00 LP3470IM5-4.00/NOPB LP3470IM5-4.38 LP3470IM5-4.38/NOPB LP3470IM5-4.63 LP3470IM5-4.63/NOPB LP3470IM5-4.8/NOPB LP3470IM5X-2.63 LP3470IM5X-2.63/NOPB LP3470IM5X-2.83/NOPB LP3470IM5X-2.93/NOPB LP3470IM5X-3.08 LP3470IM5X-3.08/NOPB LP3470IM5X-4.00 LP3470IM5X-4.00/NOPB LP3470IM5X-4.38/NOPB LP3470IM5X-4.63/NOPB LP3470M5-2.63 LP3470M5-2.63/NOPB LP3470M5-2.93/NOPB LP3470M5-3.08 LP3470M5-3.08/NOPB LP3470M5-4.00/NOPB LP3470M5-4.38/NOPB LP3470M5-4.63 LP3470M5-4.63/NOPB LP3470M5X-2.93/NOPB LP3470M5X-3.08/NOPB LP3470M5X-4.00/NOPB LP3470M5X-4.63/NOPB
- Semiconductors > Power Management > Supervisor and Reset IC
LP3470IM5X2.83/NOPB, LP3470IM5X 2.83/NOPB
