Datasheet Texas Instruments LP3907SQ-BJXQX/NOPB — Даташит
СерияLP3907
МодельLP3907SQ-BJXQX/NOPB
LP3907 Двойные понижающие преобразователи на 1 А и 600 мА и два LDO на 300 мА с интерфейсом I2C 24-WQFN от -40 до 85
LP3907 Dual 1-A and 600-mA Buck Converters and Dual 300-mA LDOs With I2C Interface datasheet
PDF, 4.0 Мб, Версия: T, Файл опубликован: 20 дек 2016
Pin24
Package TypeRTW
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
CarrierSMALL T&R
Маркировка07BJXQX
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Iout(Max)1 A
Iq(Typ)0.03 мА
LDO2
Package GroupWQFN
Package Size: mm2:W x L24WQFN: 16 mm2: 4 x 4(WQFN) PKG
Processor NameAdvanced Apps Processors,FPGA,Generic
Processor SupplierGeneric
Regulated Outputs4
Shutdown Current(Typ)0.01 uA
Special FeaturesComm Control,Dynamic Voltage Scaling,Enable,Over Current Protection,Power Good,Synchronous Rectification,Thermal Shutdown,UVLO Adjustable
Step-Down DC/DC Converter2
Switching Frequency(Max)2600 kHz
Switching Frequency(Typ)2100 kHz
Vin(Max)5.5 В
Vin(Min)1.74 В
Vout(Max)3.5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LP3907TLEVM
    LP3907 Dual High Current Step Down DC/DC & Dual Linear Regulators w/I2C Interface Evaluation Module
  • Evaluation Modules & Boards: LP3907SQ-JXQXEV
    LP3907SQ-JXQX Evaluation Board
  • Parasitics can Hinder Switcher Regulator and LDO Designs (Rev. A)
    PDF, 6.1 Мб, Версия: A, Файл опубликован: 1 июл 2014
  • Saving Energy via Smart Power Management (Power Designer-118)
    PDF, 395 Кб, Файл опубликован: 17 фев 2012
  • Enhancing Bit-Flip Recovery and PMU Design For Defense/Industrial Applications
    PDF, 49 Кб, Файл опубликован: 14 авг 2014
    Customers have evaluated several TI power-management (PMU) devices and have found that somedesigns can make the PMUs operate beyond typical data-sheet application specifications. This reportreviews the backgrounds of various relevant design features of a family of 5-V CMOS sub-PMUs,suggests solutions to accommodate system requirements, mitigates radiation concerns, and proposesbest practic
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
LP3907SQBJXQX/NOPB, LP3907SQ BJXQX/NOPB
На английском языке: Datasheet Texas Instruments LP3907SQ-BJXQX/NOPB
