Datasheet Texas Instruments MSP430FG6625 — Даташит
СерияMSP430FG6625
MSP430FG662x Микроконтроллер смешанных сигналов
MSP430FG662x, MSP430FG642x Mixed-SignalMicrocontrollers datasheet
PDF, 3.2 Мб, Файл опубликован: 22 май 2015
MSP430FG6625IPZRMSP430FG6625IZQWR
N12
Pin100113
Package TypePZZQW
Industry STD TermLQFPBGA MICROSTAR JUNIOR
JEDEC CodeS-PQFP-GS-PBGA-N
Package QTY10002500
CarrierLARGE T&RLARGE T&R
МаркировкаFG6625FG6625
Width (мм)147
Length (мм)147
Thickness (мм)1.4.74
Pitch (мм).5.5
Max Height (мм)1.61
Parameters / ModelsMSP430FG6625IPZR
MSP430FG6625IPZR
MSP430FG6625IZQWR
MSP430FG6625IZQWR
ADCSigmaDelta16 - 10chSigmaDelta16 - 10ch
AESN/AN/A
Active Power, uA/MHz250250
Additional FeaturesOpAmp,DAC,USB,LCD,Real-Time Clock,Temp Sensor,Brown Out ResetOpAmp,DAC,USB,LCD,Real-Time Clock,Temp Sensor,Brown Out Reset
BSLUSBUSB
CPUMSP430MSP430
Comparators1212
DMA66
Featuredf6f6
Тактовая частота, МГц2020
GPIO Pins7373
I2C22
Max VCC3.63.6
Min VCC1.81.8
Multiplier32x3232x32
Non-volatile Memory, KB6464
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupLQFPBGA MICROSTAR JUNIOR
Package Size: mm2:W x L, PKG100LQFP: 256 mm2: 16 x 16(LQFP)113BGA MICROSTAR JUNIOR: 49 mm2: 7 x 7(BGA MICROSTAR JUNIOR)
RAM, KB1010
RatingCatalogCatalog
SPI44
Special I/ON/AN/A
Standby Power, LPM3-uA3.43.4
Timers - 16-bit44
UART22
Wakeup Time, us33
RoHSСовместимСовместим
  • Using the MSP430 RTC_B Module With Battery Backup Supply (Rev. B)
    PDF, 135 Кб, Версия: B, Файл опубликован: 4 июн 2015
    Some applications need to retain an accurate real-time clock (RTC) through battery changes, power outages, and other events. For these applications, MSP430в„ў devices that contain the RTC_B Real-Time Clock module with a Battery Backup System can be a great fit. This application note demonstrates how to use RTC_B with Battery Backup Supply functionality to retain the time and keep the RTC counting th
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Advanced Debugging Using the Enhanced Emulation Module (EEM) With CCS v6 (Rev. F)
    PDF, 837 Кб, Версия: F, Файл опубликован: 6 сен 2016
Серия: MSP430FG6625 (2)
  • Semiconductors> Microcontrollers (MCU)> MSP430 ultra-low-power MCUs> MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430FG6625
