Datasheet Texas Instruments MSP430FR5964IPM — Даташит
СерияMSP430FR5964
МодельMSP430FR5964IPM
16 MHz Ultra-Low-Power MCU With 256 KB FRAM, 8 KB SRAM, AES, 12-bit ADC​ 64-LQFP -40 to 85
MSP430FR599x, MSP430FR596x Mixed-Signal Microcontrollers datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 31 янв 2017
Pin64
Package TypePM
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY160
Width (мм)10
Length (мм)10
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC12 - 20ch
AESAES256
Active Power (uA/MHz)120
Additional FeaturesReal-Time Clock
Watchdog
Temp Sensor
Brown Out Reset
IrDA
Approx. Price (US$)3.25 | 1ku
BSLUART
CPUMSP430
Comparators(Inputs)16
DMA6
Frequency(MHz)16
GPIO Pins(#)68
I2C4
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory (KB)256
Operating Temperature Range(C)-40 to 85
Package GroupLQFP
Package Size: mm2:W x L (PKG)64LQFP: 144 mm2: 12 x 12(LQFP)
RAM(KB)8
SPI8
Special I/ON/A
Standby Power (LPM3-uA)0.7
Timers - 16-bit6
UART4
Wakeup Time (us)7
RoHSНе совместим
  • Evaluation Modules & Boards: MSP-TS430PN80B
    Target Development Board for MSP430FR599x MCUs with 80-pins (microcontroller not included)
  • Evaluation Modules & Boards: MSP-EXP430FR5994
    MSP430FR5994 LaunchPad Development Kit
  • Evaluation Modules & Boards: BOOSTXL-AUDIO
    Audio Signal Processing BoosterPack Plug-In Module
  • Evaluation Modules & Boards: 430BOOST-SHARP96
    Sharp В® Memory LCD BoosterPack
    MSP EnergyTrace Technology
  • Benchmarking the Signal Processing Capabilities of the Low-Energy Accelerator (Rev. B)
    PDF, 922 Кб, Версия: B, Файл опубликован: 1 ноя 2016
    This application report covers the performance of the low-energy accelerator (LEA) in advanced signal processing while maintaining the ultra-low-power consumption on a 16-bit MSP430в„ў FRAM microcontroller (MCU). The LEA module is compared against the performance of optimized software-enabled signal processing code running on both the 16-bit MSP430 MCUs and a competitor ARMВ® CortexВ®-M0+ based MCU. T
  • Low-Energy Accelerator (LEA) Frequently Asked Questions (FAQ)
    PDF, 282 Кб, Файл опубликован: 1 ноя 2016
    This document answers common questions about the low-energy accelerator (LEA) module built for signal processing on the MSP430 FRAM MCUs. It describes how to get started with devices that support the LEA module and use it to perform efficient signal processing, matrix multiplication, and other operations.
  • Random Number Generation Using MSP430FR59xx and MSP430FR69xx Microcontrollers
    PDF, 113 Кб, Файл опубликован: 18 янв 2017
    Random number generation has a role in a variety of applications, such as cryptography and tamper detection.In digital systems, it becomes difficult to introduce the concept of true randomness as a machine executes code in the sequence it is programed. This introduces the notion of true random number generators (TRNGs) and pseudorandom number generators (PRNGs), also known as deterministic rando
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR5964IPM
