Datasheet Texas Instruments MSP430FR59941IPNR — Даташит
СерияMSP430FR59941
МодельMSP430FR59941IPNR
Микроконтроллер со сверхнизким энергопотреблением, тактовая частота 16 МГц, 128 КБ FRAM, 8 КБ SRAM, низкоэнергетический векторный математический ускоритель 80-LQFP от -40 до 85
MSP430FR599x, MSP430FR596x Mixed-Signal Microcontrollers datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 31 янв 2017
Pin80
Package TypePN
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаFR59941
Width (мм)12
Length (мм)12
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC12 - 20ch
AESAES256
Active Power120 uA/MHz
Additional FeaturesLEA,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
Comparators16
DMA6
Featuredfr5
Тактовая частота16 МГц
GPIO Pins68
I2C4
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory256 KB
Package GroupLQFP
Package Size: mm2:W x L64LQFP: 144 mm2: 12 x 12(LQFP) PKG
RAM8 KB
SPI8
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power0.7 LPM3-uA
Timers - 16-bit6
UART4
Wakeup Time7 us
  • Evaluation Modules & Boards: MSP-TS430PN80B
    Target Development Board for MSP430FR599x MCUs with 80-pins (microcontroller not included)
  • Evaluation Modules & Boards: MSP-EXP430FR5994
    MSP430FR5994 LaunchPad Development Kit
  • Evaluation Modules & Boards: MSP-FET430U80B
    80-pin Target Development Board MCUs and MSP-FET Programmer Bundle for MSP430FR599x MCUs
  • Evaluation Modules & Boards: BOOSTXL-AUDIO
    Audio Signal Processing BoosterPack Plug-In Module
  • Evaluation Modules & Boards: 430BOOST-SHARP96
    Sharp В® Memory LCD BoosterPack
    MSP EnergyTrace Technology
  • Benchmarking the Signal Processing Capabilities of the Low-Energy Accelerator (Rev. B)
    PDF, 922 Кб, Версия: B, Файл опубликован: 1 ноя 2016
    This application report covers the performance of the low-energy accelerator (LEA) in advanced signal processing while maintaining the ultra-low-power consumption on a 16-bit MSP430в„ў FRAM microcontroller (MCU). The LEA module is compared against the performance of optimized software-enabled signal processing code running on both the 16-bit MSP430 MCUs and a competitor ARMВ® CortexВ®-M0+ based MCU. T
  • Low-Energy Accelerator (LEA) Frequently Asked Questions (FAQ)
    PDF, 282 Кб, Файл опубликован: 1 ноя 2016
    This document answers common questions about the low-energy accelerator (LEA) module built for signal processing on the MSP430 FRAM MCUs. It describes how to get started with devices that support the LEA module and use it to perform efficient signal processing, matrix multiplication, and other operations.
  • Random Number Generation Using MSP430FR59xx and MSP430FR69xx Microcontrollers
    PDF, 113 Кб, Файл опубликован: 18 янв 2017
    Random number generation has a role in a variety of applications, such as cryptography and tamper detection.In digital systems, it becomes difficult to introduce the concept of true randomness as a machine executes code in the sequence it is programed. This introduces the notion of true random number generators (TRNGs) and pseudorandom number generators (PRNGs), also known as deterministic rando
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR59941IPNR
