Datasheet Texas Instruments MSP430FR6970 — Даташит
СерияMSP430FR6970
MSP430FR6970 Микроконтроллер со сверхнизким энергопотреблением, частота 16 МГц, 32 КБ FRAM, 2 КБ SRAM, 51 ввод-вывод, ADC12, ЖК-дисплей
MSP430FR697x(1), MSP430FR687x(1), MSP430FR692x(1), MSP430FR682x(1) Mixed‑Signal Microcontrollers datasheet
PDF, 2.9 Мб, Версия: D, Файл опубликован: 24 янв 2017
MSP430FR6970IPMRMSP430FR6970IRGCR
N12
Pin6464
Package TypePMRGC
Industry STD TermLQFPVQFN
JEDEC CodeS-PQFP-GS-PQFP-N
Package QTY10002000
CarrierLARGE T&RLARGE T&R
МаркировкаFR6970FR6970
Width (мм)109
Length (мм)109
Thickness (мм)1.4.88
Pitch (мм).5.5
Max Height (мм)1.61
Parameters / ModelsMSP430FR6970IPMR
MSP430FR6970IPMR
MSP430FR6970IRGCR
MSP430FR6970IRGCR
ADCADC12 - 8chADC12 - 8ch
AESAES256AES256
Active Power, uA/MHz101.25101.25
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA,IP ProtectionReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA,IP Protection
BSLUARTUART
CPUMSP430MSP430
Comparators88
DMA33
Featuredfr6fr6
Тактовая частота, МГц1616
GPIO Pins5151
I2C22
Max VCC3.63.6
Min VCC1.81.8
Multiplier32x3232x32
Non-volatile Memory, KB3232
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupLQFPVQFN
Package Size: mm2:W x L, PKG64LQFP: 144 mm2: 12 x 12(LQFP)64VQFN: 81 mm2: 9 x 9(VQFN)
RAM, KB22
RatingCatalogCatalog
SPI44
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protectionCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/AN/A
Standby Power, LPM3-uA0.90.9
Timers - 16-bit55
UART22
Wakeup Time, us77
RoHSСовместимСовместим
  • Secure In-Field Firmware Updates for MSP MCUs
    PDF, 223 Кб, Файл опубликован: 17 ноя 2015
    In-field firmware update is a feature that is increasingly used in microcontroller-based applications today and important benefits include service and support to products that are already deployed in the field (for example, being able to correct bugs or add new functionalities). As common as in-field firmware updates are in embedded systems, this feature is also commonly exploited by attackers; if
  • Random Number Generation Using MSP430FR59xx and MSP430FR69xx Microcontrollers
    PDF, 113 Кб, Файл опубликован: 18 янв 2017
    Random number generation has a role in a variety of applications, such as cryptography and tamper detection.In digital systems, it becomes difficult to introduce the concept of true randomness as a machine executes code in the sequence it is programed. This introduces the notion of true random number generators (TRNGs) and pseudorandom number generators (PRNGs), also known as deterministic rando
  • Getting Started With EEMBC ULPBench on MSP-EXP430FR5969 (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 29 янв 2015
    This is a getting started guide for obtaining the ULPMarkв„ў-CP score using the Embedded Microprocessor Benchmark Consortium (EEMBC) ULPBench and EnergyMonitor with the MSP430FR5969 microcontroller (MCU). This document uses the MSP-EXP430FR5969 LaunchPad development kit as the target evaluation module (EVM) for performing the benchmark.
  • Migrating From MSP430F4xx Family to MSP430FR58xx/FR59xx/FR68xx/FR69xx Family (Rev. B)
    PDF, 183 Кб, Версия: B, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR58xx/59xx/68xx/69xx family of FRAM-based MCUs. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR58xx/FR59xx/68xx/69xx devices, see the MSP430FR58xx, MSP430FR59xx, MSP430FR68xx, and MSP430FR69xx Family User's Guide.
  • Designing With the MSP430FR58xx, FR59xx, FR68xx, and FR69xx ADC (Rev. A)
    PDF, 137 Кб, Версия: A, Файл опубликован: 30 мар 2016
    Designing an application with the analog-to-digital converter (ADC) requires several considerations to optimize for power and performance. This application report discusses the basics of how you would analyze a data sheet and user's guide to design your application. It goes into the fundamentals of how to optimize your design based on the external requirements and available ADC configurations. The
  • MSP430 Advanced Power Optimizations: ULP Advisor SW and EnergyTrace Technology
    PDF, 4.0 Мб, Файл опубликован: 9 июн 2014
    MSP430 microcontrollers are designed specifically for ultra-low-power applications. Features such as multiple low-power modes, instant wakeup, intelligent autonomous peripherals, and much more to enable such ultra-low-power capabilities. Texas Instruments provides valuable tools to help the programmer fully use these benefits and optimize power consumption of the target application. This app
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)
    PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
    This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
  • Migrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)
    PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two f
Серия: MSP430FR6970 (2)
  • Semiconductors> Microcontrollers (MCU)> MSP430 ultra-low-power MCUs> MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR6970
