Datasheet Texas Instruments OMAP3515ECUSA — Даташит
СерияOMAP3515
МодельOMAP3515ECUSA
Процессор Sitara: ARM Cortex-A8, 3D-графика, LPDDR 423-FCBGA от -40 до 105
OMAP3515 and OMAP3503 Applications Processors datasheet
PDF, 2.7 Мб, Версия: H, Файл опубликован: 10 окт 2013
Pin423423
Package TypeCUSCUS
Industry STD TermFC/CSPFC/CSP
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY9090
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаA3515ECUS
Width (мм)1616
Length (мм)1616
Thickness (мм).96.96
Pitch (мм).65.65
Max Height (мм)1.41.4
ARM CPU1 ARM Cortex-A8
ARM MHz720 Max.
ApplicationsCommunications Equipment,Enterprise Systems,Industrial,Personal Electronics
DRAMLPDDR
Display OptionsDSS
Graphics Acceleration1 3D
I2C3
On-Chip L2 Cache256 KB (ARM Cortex-A8)
Operating SystemsIntegrity,Linux,Neutrino,Tornado,VxWorks,Windows Embedded CE
Рабочий диапазон температурот -40 до 105,0 до 90 C
Other On-Chip Memory64 KB
SPI4
UART3 SCI
USB2
  • Evaluation Modules & Boards: TMDSEVM3530
    OMAP35x Evaluation Module (EVM)
    XDS200 USB Debug Probe
  • OMAP35x 0.65mm Pitch Layout Methods (Rev. B)
    PDF, 372 Кб, Версия: B, Файл опубликован: 26 июн 2008
    It is easy to see from the unique look that the OMAP35x parts have a very unusual footprint. The OMAP35x ball grid array is designed with new technology called the Via Channel array which makes significant printed circuit board (PCB) cost savings possible. If the PCB is routed correctly this cost savings can be substantial. This application report explains how this is possible and shows several
  • OMAP3530/25/15/03 CBB CBC & CUS Reflow Profiles
    PDF, 27 Кб, Файл опубликован: 13 ноя 2009
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at:
    http://wiki.davincidsp.com/index.php/OMAP3_CBB_CBC_CUS_Reflow_Profiles
    Reflow profiles are dependent on numerous factors including package type number of components bo
  • OMAP35x Linux PSP Data Sheet
    PDF, 1.6 Мб, Файл опубликован: 16 окт 2009
  • Powering OMAP3 With TPS65023: Design-In Guide (Rev. B)
    PDF, 181 Кб, Версия: B, Файл опубликован: 2 мар 2009
  • OMAP35x to AM35x Hardware Migration Guide
    PDF, 19 Кб, Файл опубликован: 24 май 2010
    http://processors.wiki.ti.com/index.php/OMAP35x_to_AM35x_Hardware_Migration_Guide.
    This article describes hardware device considerations to migrate a design
  • Powering OMAP3 With TPS6235x: Design-In Guide
    PDF, 296 Кб, Файл опубликован: 3 дек 2008
    The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution.
  • OMAP35x to AM37x Hardware Migration Guide
    PDF, 37 Кб, Файл опубликован: 3 июн 2010
    http://processors.wiki.ti.com/index.php/OMAP35x_To_AM37x_Hardware_Migration_Guide.
    The OMAP35x to AM37x Hardware Migration Guide describes device consideratio
  • PCB Assembly Guidelines for 0.4mm Package-On-Package (PoP) Packages Part II (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 1 ноя 2013
    Once the bottom circuit board has been designed the assembly guidelines for package-on-package (PoP) versions of the OMAP35xx processor and the memory device must be considered.
    PoP packages have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of final assembly: the circuit board design the solder paste char
  • PCB Design Guidelines for 0.4mm Package-On-Package (PoP) Packages Part I (Rev. B)
    PDF, 6.7 Мб, Версия: B, Файл опубликован: 13 июн 2009
    Ball grid array (BGA) packages having 0.4mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies; the standard rules of thumb don't apply anymore. In fact the design guidelines for 0.4mm and 0.5mm differ primarily due to issues surrounding shorts or opens between balls under the processor.In addition to the de
  • PCB Design Guidelines for 0.5mm Package-On-Package Apps Processors Part I
    PDF, 2.0 Мб, Файл опубликован: 23 июн 2010
    Ball grid array (BGA) packages having 0.5mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies. PCBs with package-on-package (PoP) technology have additional assembly requirements and options that need to be considered when designing the PCB.
    Fine-pitch PCB design is a team effort and may require more than
  • PCB Assembly Guidelines for 0.5mm Package-on-Package Apps Processors Part II
    PDF, 1.2 Мб, Файл опубликован: 23 июн 2010
    Once the main printed circuit board (PCB) has been designed the assembly guidelines for the 0.5mm package-on-package (PoP) applications processor and companion memory device must be considered. PoP applications processors have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of PCB assembly: PoP applications process
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A8 > AM3x
На английском языке: Datasheet Texas Instruments OMAP3515ECUSA
