Datasheet Texas Instruments OMAP3530ECBC72 — Даташит
СерияOMAP3530
МодельOMAP3530ECBC72
Прикладной процессор 515-POP-FCBGA от 0 до 90
OMAP3530 and OMAP3525 Applications Processors datasheet
PDF, 2.7 Мб, Версия: H, Файл опубликован: 10 окт 2013
Pin515
Package TypeCBC
Industry STD TermPOP-FCBGA
JEDEC CodeS-PBGA-N
Package QTY119
Маркировка3530ECBC72
Width (мм)14
Length (мм)14
Thickness (мм).63
Pitch (мм).5
Max Height (мм).95
2D & 3D GraphicsHardware Accelerated
ARM CPU1 ARM Cortex-A8
ARM MHz720 Max.
Integrated TI C64x DSPUp to 520 MHz
Memory Interface1 16-bit LPDDR , 1 32-bit SDRC Dual Channel
PerformanceD1
Process Node65nm
  • Evaluation Modules & Boards: TMDSEVM3530
    OMAP35x Evaluation Module (EVM)
  • OMAP3530 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 8 янв 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at: http://wiki.davincidsp.com/index.php/OMAP3530_Power_Estimation_Spreadsheet.
    Power consumption on the OMAP3530 device is highly application-dependent therefore a sp
  • OMAP3530 Easy CUS Package PCB Escape Routing (Rev. A)
    PDF, 2.6 Мб, Версия: A, Файл опубликован: 25 мар 2010
    The OMAP3530 CUS package is designed with a new technology called Via Channel™ array. This technology allows for easy routing of the device in two signal and two power layers using standard 20 mil diameter and 10 mil finished hole size via; it is cost and time effective. This application report shows how to easily route the entire package by first routing one quadrant only and then copying i
  • Ultrasound Scan Conversion on TI's C64x+ DSPs
    PDF, 656 Кб, Файл опубликован: 3 апр 2009
    One of the recent significant developments in ultrasound is the emergence of portable and handheld ultrasound machines and their rapid acceptance in the market place.Because of their power efficiency and high performance digital signal processor (DSP) based devices have been increasingly used as the main processing engine in these portable and hand carried units.
    This application report dis
  • OMAP35x Linux PSP Data Sheet
    PDF, 1.6 Мб, Файл опубликован: 16 окт 2009
  • OMAP3530/25/15/03 CBB CBC & CUS Reflow Profiles
    PDF, 27 Кб, Файл опубликован: 13 ноя 2009
    http://wiki.davincidsp.com/index.php/OMAP3_CBB_CBC_CUS_Reflow_Profiles
    Reflow profiles are dependent on numerous factors including package type number of components bo
  • OMAP35x 0.65mm Pitch Layout Methods (Rev. B)
    PDF, 372 Кб, Версия: B, Файл опубликован: 26 июн 2008
    It is easy to see from the unique look that the OMAP35x parts have a very unusual footprint. The OMAP35x ball grid array is designed with new technology called the Via Channel array which makes significant printed circuit board (PCB) cost savings possible. If the PCB is routed correctly this cost savings can be substantial. This application report explains how this is possible and shows several
  • Powering OMAP3 With TPS65023: Design-In Guide (Rev. B)
    PDF, 181 Кб, Версия: B, Файл опубликован: 2 мар 2009
  • OMAP35x to AM35x Hardware Migration Guide
    PDF, 19 Кб, Файл опубликован: 24 май 2010
    http://processors.wiki.ti.com/index.php/OMAP35x_to_AM35x_Hardware_Migration_Guide.
    This article describes hardware device considerations to migrate a design
  • OMAP35x to AM37x Hardware Migration Guide
    PDF, 37 Кб, Файл опубликован: 3 июн 2010
    http://processors.wiki.ti.com/index.php/OMAP35x_To_AM37x_Hardware_Migration_Guide.
    The OMAP35x to AM37x Hardware Migration Guide describes device consideratio
  • PCB Design Guidelines for 0.4mm Package-On-Package (PoP) Packages Part I (Rev. B)
    PDF, 6.7 Мб, Версия: B, Файл опубликован: 13 июн 2009
    Ball grid array (BGA) packages having 0.4mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies; the standard rules of thumb don't apply anymore. In fact the design guidelines for 0.4mm and 0.5mm differ primarily due to issues surrounding shorts or opens between balls under the processor.In addition to the de
  • PCB Assembly Guidelines for 0.4mm Package-On-Package (PoP) Packages Part II (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 1 ноя 2013
    Once the bottom circuit board has been designed the assembly guidelines for package-on-package (PoP) versions of the OMAP35xx processor and the memory device must be considered.
    PoP packages have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of final assembly: the circuit board design the solder paste char
  • PCB Assembly Guidelines for 0.5mm Package-on-Package Apps Processors Part II
    PDF, 1.2 Мб, Файл опубликован: 23 июн 2010
    Once the main printed circuit board (PCB) has been designed the assembly guidelines for the 0.5mm package-on-package (PoP) applications processor and companion memory device must be considered. PoP applications processors have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of PCB assembly: PoP applications process
  • PCB Design Guidelines for 0.5mm Package-On-Package Apps Processors Part I
    PDF, 2.0 Мб, Файл опубликован: 23 июн 2010
    Ball grid array (BGA) packages having 0.5mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies. PCBs with package-on-package (PoP) technology have additional assembly requirements and options that need to be considered when designing the PCB.
    Fine-pitch PCB design is a team effort and may require more than
  • Running a TMS320C64x+ Codec Across TMS320C64x+ Based DSP Platforms
    PDF, 969 Кб, Файл опубликован: 24 сен 2009
    This application report describes the device differences to be taken care for running the C64x+™ video codec software on different C64x+ based platforms. This document assumes that the codec software is developed for the C64x+ digital signal processor (DSP) core. As many TI platforms have a C64x+ DSP this document gives the details for running the standalone codec software on a C64x+ platfo
  • Semiconductors > OMAP™ Applications Processors > OMAP™ Processors > OMAP™ 3 Processors
На английском языке: Datasheet Texas Instruments OMAP3530ECBC72
