Datasheet Texas Instruments ONET1101LRGER — Даташит
СерияONET1101L
МодельONET1101LRGER
Драйвер лазерного диода 11,3 Гбит/с 24-VQFN от -25 до 100
11.3 Gbps Laser Diode Driver datasheet
PDF, 1.0 Мб, Файл опубликован: 17 мар 2008
Pin2424
Package TypeRGERGE
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаONET1101L
Width (мм)44
Length (мм)44
Thickness (мм).88.88
Pitch (мм).5.5
Max Height (мм)11
DJ(Typ)5 ps
Data Rate(Max)11.3 Gbps
ICC(Max)118 мА
ICC(Typ)66 мА
Imod85 мА
Рабочий диапазон температурот -25 до 100 C
Package GroupVQFN
Package Size: mm2:W x L24VQFN: 16 mm2: 4 x 4(VQFN) PKG
Special FeaturesBias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital Select
Tf-out(Typ)25 ps
Tr-out(Typ)25 ps
VCC3.3 В
  • Considerations for PCB Layout and Impedance Matching Design in Optical Modules
    PDF, 1.0 Мб, Файл опубликован: 15 фев 2011
    The optical module offers an effective high-speed solution for a growing telecom market. Data rates range from 155 Mbps to 6 Gbps and even up to 10 Gbps. Transmitter optical sub-assemblies (TOSAs) and laser drivers may have different resistances in a given application, so the reflection could be worse if the designer does not use an impedance transfer circuit to absorb it. Additional uncertain noi
Серия: ONET1101L (3)
  • Semiconductors > Interface > Optical Networking IC > Laser Drivers
На английском языке: Datasheet Texas Instruments ONET1101LRGER
