Datasheet Texas Instruments ONET1101LRGET — Даташит
Серия | ONET1101L |
Модель | ONET1101LRGET |
Драйвер лазерного диода 11,3 Гбит/с 24-VQFN от -25 до 100
11.3 Gbps Laser Diode Driver datasheet
PDF, 1.0 Мб, Файл опубликован: 17 мар 2008
Pin | 24 | 24 |
Package Type | RGE | RGE |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | ONET | 1101L |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .88 | .88 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
DJ(Typ) | 5 ps |
Data Rate(Max) | 11.3 Gbps |
ICC(Max) | 118 мА |
ICC(Typ) | 66 мА |
Imod | 85 мА |
Рабочий диапазон температур | от -25 до 100 C |
Package Group | VQFN |
Package Size: mm2:W x L | 24VQFN: 16 mm2: 4 x 4(VQFN) PKG |
Special Features | Bias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital Select |
Tf-out(Typ) | 25 ps |
Tr-out(Typ) | 25 ps |
VCC | 3.3 В |
- Considerations for PCB Layout and Impedance Matching Design in Optical ModulesPDF, 1.0 Мб, Файл опубликован: 15 фев 2011
The optical module offers an effective high-speed solution for a growing telecom market. Data rates range from 155 Mbps to 6 Gbps and even up to 10 Gbps. Transmitter optical sub-assemblies (TOSAs) and laser drivers may have different resistances in a given application, so the reflection could be worse if the designer does not use an impedance transfer circuit to absorb it. Additional uncertain noi
Серия: ONET1101L (3)
- ONET1101LRGER ONET1101LRGET ONET1101LRGETG4
- Semiconductors > Interface > Optical Networking IC > Laser Drivers
