Datasheet Texas Instruments ONET1101L — Даташит
СерияONET1101L
Драйвер лазерного диода 11,3 Гбит/с
11.3 Gbps Laser Diode Driver datasheet
PDF, 1.0 Мб, Файл опубликован: 17 мар 2008
ONET1101LRGERONET1101LRGETONET1101LRGETG4
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетДаДа
N123
Pin242424
Package TypeRGERGERGE
Industry STD TermVQFNVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-NS-PQFP-N
Package QTY3000250250
CarrierLARGE T&RSMALL T&RSMALL T&R
МаркировкаONETONET1101L
Width (мм)444
Length (мм)444
Thickness (мм).88.88.88
Pitch (мм).5.5.5
Max Height (мм)111
Parameters / ModelsONET1101LRGER
ONET1101LRGER
ONET1101LRGET
ONET1101LRGET
ONET1101LRGETG4
ONET1101LRGETG4
DJ(Typ), ps555
Data Rate(Max), Gbps11.311.311.3
ICC(Max), мА118118118
ICC(Typ), мА666666
Imod, мА858585
Рабочий диапазон температур, Cот -25 до 100от -25 до 100от -25 до 100
Package GroupVQFNVQFNVQFN
Package Size: mm2:W x L, PKG24VQFN: 16 mm2: 4 x 4(VQFN)24VQFN: 16 mm2: 4 x 4(VQFN)24VQFN: 16 mm2: 4 x 4(VQFN)
Special FeaturesBias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital SelectBias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital SelectBias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital Select
Tf-out(Typ), ps252525
Tr-out(Typ), ps252525
VCC, В3.33.33.3
  • Considerations for PCB Layout and Impedance Matching Design in Optical Modules
    PDF, 1.0 Мб, Файл опубликован: 15 фев 2011
    The optical module offers an effective high-speed solution for a growing telecom market. Data rates range from 155 Mbps to 6 Gbps and even up to 10 Gbps. Transmitter optical sub-assemblies (TOSAs) and laser drivers may have different resistances in a given application, so the reflection could be worse if the designer does not use an impedance transfer circuit to absorb it. Additional uncertain noi
  • Semiconductors> Interface> Optical Module IC> Laser Driver
На английском языке: Datasheet Texas Instruments ONET1101L
