Datasheet Texas Instruments ONET8501VRGPTG4 — Даташит
СерияONET8501V
МодельONET8501VRGPTG4
Дифференциальный драйвер VCSEL 11,3 Гбит/с с формированием выходного сигнала 20-QFN от -40 до 85
11.3 Gbps Differential VCSEL Driver w/Output Waveform Shaping datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 20 авг 2007
Pin2020
Package TypeRGPRGP
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаONET8501V
Width (мм)44
Length (мм)44
Thickness (мм).93.93
Pitch (мм).5.5
Max Height (мм)11
DJ(Typ)4 ps
Data Rate(Max)11.3 Gbps
ICC(Max)90 мА
ICC(Typ)50 мА
Imod24 мА
Package GroupQFN
Package Size: mm2:W x L20QFN: 16 mm2: 4 x 4(QFN) PKG
Special FeaturesBias Current Digital Select,2-Wire Interface,Automatic Power Control Loop,Modulation Current Digital Select
Tf-out(Typ)24 ps
Tr-out(Typ)24 ps
VCC3.3 В
  • Considerations for PCB Layout and Impedance Matching Design in Optical Modules
    PDF, 1.0 Мб, Файл опубликован: 15 фев 2011
    The optical module offers an effective high-speed solution for a growing telecom market. Data rates range from 155 Mbps to 6 Gbps and even up to 10 Gbps. Transmitter optical sub-assemblies (TOSAs) and laser drivers may have different resistances in a given application, so the reflection could be worse if the designer does not use an impedance transfer circuit to absorb it. Additional uncertain noi
  • Semiconductors > Interface > Optical Networking IC > Laser Drivers
На английском языке: Datasheet Texas Instruments ONET8501VRGPTG4
