Datasheet ТI OPA2187IDGKT — Даташит
| Серия | OPA2187 |
| Модель | OPA2187IDGKT |
1ВµV Vos, 0.005ВµV/В°C, Rail-to-Rail Output, Low-Power 36V Zero-Drift Operational Amplifier 8-VSSOP -40 to 125
OPAx187 0.005-µV/В°C Drift, Low Power, Rail-to-Rail Output 36-V Operational Amplifiers Zero-Drift Series datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 28 июл 2017
- Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2187 (4)
- OPA2187ID OPA2187IDGKR OPA2187IDGKT OPA2187IDR
