Datasheet Texas Instruments OPA2191IDR — Даташит
Серия | OPA2191 |
Модель | OPA2191IDR |
Low-Power, Precision, 36-V, e-trimВ CMOS Amplifier 8-SOIC -40 to 125
OPAx191 36-V, Low Power, Precision, CMOS, Rail-to-Rail Input/Output, Low Offset Voltage, Low Input Bias Current Op Amp datasheet
PDF, 3.3 Мб, Версия: A, Файл опубликован: 12 апр 2016
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2191 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | EMI Hardened,High Cload Drive |
Архитектура | CMOS |
CMRR(Min) | 120 дБ |
CMRR(Typ) | 140 дБ |
GBW(Typ) | 2.5 МГц |
Input Bias Current(Max) | 20 pA |
Iq per channel(Max) | 0.2 мА |
Iq per channel(Typ) | 0.14 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.15 uV/C |
Output Current(Typ) | 65 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 5.5 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 15 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.025 мВ |
- Evaluation Modules & Boards: DIP-ADAPTER-EVM
DIP Adapter Evaluation Module
- MUX-Friendly: Definition and BenefitsPDF, 212 Кб, Файл опубликован: 18 сен 2017
- Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2191 (4)
- OPA2191ID OPA2191IDGKR OPA2191IDGKT OPA2191IDR
