Datasheet Texas Instruments PCI2250PGF — Даташит
| Серия | PCI2250 |
| Модель | PCI2250PGF |
32-разрядный мост PCI-PCI, 33 МГц, компактный PCI, поддерживающий горячую замену, 4-Master 176-LQFP от 0 до 70
Купить PCI2250PGF на РадиоЛоцман.Цены — от 368 до 2 714 ₽16 предложений от 16 поставщиков IC INTFACE SPECIALIZED 176LQFP. PCI-to-PCI Bridge Interface 176-LQFP (24x24). Interface - Specialized | |||
| PCI2250PGF Texas Instruments | 467 ₽ | ||
| PCI2250PGF Texas Instruments | 604 ₽ | ||
| PCI2250PGF Texas Instruments | 2 595 ₽ | ||
| PCI2250PGF Texas Instruments | по запросу | ||
| Pin | 176 |
| Package Type | PGF |
| Industry STD Term | LQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 40 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | PCI2250PGF |
| Width (мм) | 24 |
| Length (мм) | 24 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | QFP |
| Package Size: mm2:W x L | 176LQFP: 576 mm2: 24 x 24(LQFP) PKG |
| Rating | Catalog |
- Connecting ENUM Terminal to an External Open-Drain BufferPDF, 38 Кб, Файл опубликован: 13 апр 2000
This application note describes how to connect the cPCI hot-swap signal ENUM on the PCI2250 to an external open-drain buffer. - Differences Between the Intel 21152 and the PCI2250PDF, 34 Кб, Файл опубликован: 31 мар 2003
This application report describes the functional difference between the Intel 21152 and the TI PCI2250. The PCI2250 is a 32-bit PCI-to-PCI bridge that was designed to be pin-to-pin compatible with the Intel 21152. The PCI2250 can also be configured to a TI specific mode that has additional capabilities.
Серия: PCI2250 (4)
- PCI2250PCM PCI2250PCMG4 PCI2250PGF PCI2250PGFG4
- Semiconductors > Interface > PCIe/SAS/SATA > PCI/PCIe PHY and Bridges
