Datasheet Texas Instruments PCM1606E/2K — Даташит
СерияPCM1606
МодельPCM1606E/2K
6-канальный аудио ЦАП 103 дБ SNR 20-SSOP от -25 до 85
24-Bit, 192-kHz Sampling, 6-Channel, Enhanced Multilevel, Delta-Sigma datasheet
PDF, 399 Кб, Версия: B, Файл опубликован: 9 авг 2002
17 предложений от 17 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
PCM1606E/2K
570 ₽
Зенер
Россия и страны ТС
PCM1606E/2K
613 ₽
Эиком
PCM1606E/2K
627 ₽
727GS
PCM1606E/2K
Pin20
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаPCM1606E
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Analog Outputs6
АрхитектураDelta-Sigma
Control InterfaceH/W
DAC Channels6
DAC SNR(Typ)103 дБ
Package Size: mm2:W x L20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • Out-of-Band Noise and Filtering for PCM DAC
    PDF, 447 Кб, Файл опубликован: 20 май 2005
Серия: PCM1606 (3)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1606E/2K
