Datasheet Texas Instruments PCM1606E — Даташит
| Серия | PCM1606 |
| Модель | PCM1606E |
6-канальный аудио ЦАП 103 дБ SNR 20-SSOP от -25 до 85
24-Bit, 192-kHz Sampling, 6-Channel, Enhanced Multilevel, Delta-Sigma datasheet
PDF, 399 Кб, Версия: B, Файл опубликован: 9 авг 2002
Купить PCM1606E на РадиоЛоцман.Цены — от 28 до 2 246 ₽27 предложений от 25 поставщиков Микросхема Преобразователь DA, TEXAS INSTRUMENTS PCM1606E Digital to Analog Converter, 24Bit, 192KSPS, Serial, 4.5V to 5.5V, SSOP, 20Pins | |||
| PCM1606E Texas Instruments | 162 ₽ | ||
| PCM1606E/2K Texas Instruments | 221 ₽ | ||
| PCM1606E/2K Texas Instruments | 613 ₽ | ||
| PCM1606E | по запросу | ||
| Pin | 20 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 65 |
| Carrier | TUBE |
| Маркировка | PCM1606E |
| Width (мм) | 5.3 |
| Length (мм) | 7.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Analog Outputs | 6 |
| Архитектура | Delta-Sigma |
| Control Interface | H/W |
| DAC Channels | 6 |
| DAC SNR(Typ) | 103 дБ |
| Package Size: mm2:W x L | 20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG |
| Разрешение | 24 Bits |
| Sampling Rate(Max) | 192 kHz |
- Out-of-Band Noise and Filtering for PCM DACPDF, 447 Кб, Файл опубликован: 20 май 2005
- THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27PDF, 107 Кб, Файл опубликован: 27 сен 2000
The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727. - A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1606 (3)
- PCM1606E PCM1606E/2K PCM1606EG4
- Semiconductors > Audio > Audio Converters > Audio DAC
