Datasheet Texas Instruments PCM1606 — Даташит
СерияPCM1606
6-канальный аудио ЦАП с соотношением сигнал/шум 103 дБ
24-Bit, 192-kHz Sampling, 6-Channel, Enhanced Multilevel, Delta-Sigma datasheet
PDF, 399 Кб, Версия: B, Файл опубликован: 9 авг 2002
PCM1606EPCM1606E/2KPCM1606EG4
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin202020
Package TypeDBDBDB
Industry STD TermSSOPSSOPSSOP
Package QTY65200065
CarrierTUBELARGE T&RTUBE
МаркировкаPCM1606EPCM1606EPCM1606E
Width (мм)5.35.35.3
Length (мм)7.27.27.2
Thickness (мм)1.951.951.95
Pitch (мм).65.65.65
Max Height (мм)222
Parameters / ModelsPCM1606E
PCM1606E
PCM1606E/2K
PCM1606E/2K
PCM1606EG4
PCM1606EG4
Analog Outputs666
АрхитектураDelta-SigmaDelta-SigmaDelta-Sigma
Control InterfaceH/WH/WH/W
DAC Channels666
DAC SNR(Typ), дБ103103103
Package Size: mm2:W x L, PKG20SSOP: 56 mm2: 7.8 x 7.2(SSOP)20SSOP: 56 mm2: 7.8 x 7.2(SSOP)20SSOP: 56 mm2: 7.8 x 7.2(SSOP)
Разрешение, Bits242424
Sampling Rate(Max), kHz192192192
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • Out-of-Band Noise and Filtering for PCM DAC
    PDF, 447 Кб, Файл опубликован: 20 май 2005
Серия: PCM1606 (3)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1606
