Datasheet Texas Instruments PCM1681PWPR — Даташит
СерияPCM1681
МодельPCM1681PWPR
8-канальный аудио ЦАП с соотношением сигнал/шум 105 дБ и режимом TDM 28-HTSSOP от -40 до 85
PCM1681 24-Bit, 192-kHz Sampling, Enhanced Multilevel Delta-Sigma, Eight-Channel Audio Digital-to-Analog Converter datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 31 июл 2015
36 предложений от 15 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
PCM1681PWPR
122 ₽
Рутоника
PCM1681PWPR
124 ₽
PCM1681PWPR
148 ₽
PCM1681PWPR
239 ₽
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаPCM1681
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs8
АрхитектураCurrent Segment DAC
Control InterfaceSPI,I2C,H/W
DAC Channels8
DAC SNR(Typ)105 дБ
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)200 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1681 (4)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1681PWPR
