Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI PCM1690 — Даташит
СерияPCM1690
Datasheet Texas Instruments PCM1690
8-канальный аудио ЦАП с соотношением сигнал/шум 113 дБ и дифференциальными выходами
PCM1690 24-Bit, 192-kHz Sampling, Enhanced Multi-Level О”ОЈ, Eight-Channel Audio Digital-to-Analog Converter datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 31 авг 2015
PCM1690DCAPCM1690DCAR
Доступность образцов у производителяДаНет
N12
Pin4848
Package TypeDCADCA
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY402000
CarrierTUBELARGE T&R
МаркировкаPCM1690PCM1690
Width (мм)6.16.1
Length (мм)12.512.5
Thickness (мм)1.151.15
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsPCM1690DCA
PCM1690DCA
PCM1690DCAR
PCM1690DCAR
Analog Outputs88
АрхитектураCurrent Segment DACCurrent Segment DAC
Control InterfaceSPI,I2C,H/WSPI,I2C,H/W
DAC Channels88
DAC SNR(Typ), дБ113113
Package Size: mm2:W x L, PKG48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP)48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP)
Разрешение, Bits2424
Sampling Rate(Max), kHz192192
RoHSСовместимСовместим
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1690 (2)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1690
Политика конфиденциальности
