Datasheet Texas Instruments PCM1690IDCARQ1 — Даташит
СерияPCM1690-Q1
МодельPCM1690IDCARQ1
Автомобильный каталог 8-канальный аудио ЦАП с соотношением сигнал/шум 113 дБ и дифференциальными выходами 48-HTSSOP от -40 до 85
24-Bit, 192-kHz Sampling, Enhanced Multi-Level О”ОЈ,Eight-Channel Audio Digital.. datasheet
PDF, 1.4 Мб, Файл опубликован: 21 июн 2011
19 предложений от 19 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
PCM1690IDCARQ1
221 ₽
PCM1690IDCARQ1
243 ₽
Hi-Tech Circuit Group
PCM1690IDCARQ1
PCM1690IDCARQ1
Pin48
Package TypeDCA
Industry STD TermHTSSOP
Package QTY2000
МаркировкаPCM1690Q
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Analog Outputs8
АрхитектураCurrent Segment
Control InterfaceSPI,I2C,H/W
DAC Channels8
DAC SNR(Typ)113 дБ
Package Size: mm2:W x L48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1690-Q1 (1)
  • PCM1690IDCARQ1
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1690IDCARQ1
Публикации по теме
