Datasheet Texas Instruments PCM1718EG4 — Даташит
СерияPCM1718
МодельPCM1718EG4
Стерео ЦАП 100 дБ SNR 20-SSOP
SoundPlus™ Stereo Audio Digital-To-Analog Converter datasheet
PDF, 347 Кб, Файл опубликован: 27 сен 2000
IC DAC/AUDIO 18BIT 48K 20SSOP. DAC, Audio 18 bit 48k I²S 20-SSOP. Data Acquisition - ADCs/DACs - Special Purpose
PCM1718EG4
802 ₽
Рутоника
PCM1718EG4
1 125 ₽
PCM1718EG4
PCM1718EG4
Pin20
Package TypeDB
Industry STD TermSSOP
Package QTY65
МаркировкаPCM1718E
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1718 (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1718EG4
