Datasheet Texas Instruments PCM1748E/2K — Даташит
СерияPCM1748
МодельPCM1748E/2K
Стерео ЦАП 106 дБ SNR 16-SSOP от -25 до 85
24-Bit 96kHz Sampling Enhanced. Multilevel Delta-Sigma Audio DAC datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 19 апр 2005
21 предложений от 18 поставщиков
Микросхема Преобразователь DA, TEXAS INSTRUMENTS PCM1748E/2K Digital to Analog Converter, 24Bit, 96KSPS, Serial, 4.5V to 5.5V, QSOP, 16Pins
Рутоника
PCM1748E/2K
130 ₽
PCM1748E/2K
151 ₽
SUV System
PCM1748E/2K
PCM1748E/2K
Pin1616
Package TypeDBQDBQ
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаPCM1748E
Width (мм)3.93.9
Length (мм)4.94.9
Thickness (мм)1.51.5
Pitch (мм).64.64
Max Height (мм)1.751.75
Analog Outputs2
АрхитектураDelta-Sigma
Control InterfaceSPI
DAC Channels2
DAC SNR(Typ)100 дБ
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)96 kHz
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1748E/2K
