Datasheet Texas Instruments PCM1754DBQ — Даташит
СерияPCM1754
МодельPCM1754DBQ
ЦАП стерео аудио с соотношением сигнал/шум 106 дБ (аппаратное управление) 16-SSOP от -25 до 85
PCM175x 24-Bit 192-kHz Sampling Enhanced Multi-Level Delta-Sigma Audio Digital-to-Analog Converter datasheet
PDF, 2.3 Мб, Версия: D, Файл опубликован: 31 авг 2015
42 предложений от 22 поставщиков
Микросхема Преобразователь DA, TEXAS INSTRUMENTS PCM1754DBQ Digital to Analogue Converter, 24Bit, 192KSPS, Serial, 4.5V to 5.5V, SSOP, 16Pins
PCM1754DBQ
от 30 ₽
PCM1754DBQ
96 ₽
Контест
PCM1754DBQ
Burr-Brown
SUV System
PCM1754DBQ
Pin16
Package TypeDBQ
Industry STD TermSSOP
Package QTY75
МаркировкаPCM1754
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Analog Outputs2
АрхитектураDelta-Sigma
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ)106 дБ
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • Out-of-Band Noise and Filtering for PCM DAC
    PDF, 447 Кб, Файл опубликован: 20 май 2005
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1754 (4)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1754DBQ
