Datasheet ТI PCM1754-Q1 — Даташит
| Серия | PCM1754-Q1 |
Автомобильный каталог ЦАП стерео аудио с соотношением сигнал/шум 106 дБ (аппаратное управление)
PCM175x-Q1 24-Bit 192-kHz Sampling Enhanced Multi-Level Delta-Sigma Audio Digital-to-Analog Converter datasheet
PDF, 2.3 Мб, Версия: D, Файл опубликован: 31 июл 2015
| PCM1754TDBQRQ1 | |
| PCM1754TDBQRQ1 | |
| N | 1 |
| Pin | 16 |
| Package Type | DBQ |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | P1754Q |
| Width (мм) | 3.9 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.5 |
| Pitch (мм) | .64 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Parameters / Models | PCM1754TDBQRQ1![]() |
| Analog Outputs | 2 |
| Архитектура | Delta-Sigma |
| Control Interface | H/W |
| DAC Channels | 2 |
| DAC SNR(Typ), дБ | 106 |
| Package Size: mm2:W x L, PKG | 16SSOP: 19 mm2: 3.9 x 4.9(SSOP) |
| Разрешение, Bits | 24 |
| Sampling Rate(Max), kHz | 192 |
| PCM1754TDBQRQ1 | |
- THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27PDF, 107 Кб, Файл опубликован: 27 сен 2000
The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1754-Q1 (1)
- Semiconductors> Audio> Audio Converters> Audio DAC
