Datasheet Texas Instruments PCM1771RGA — Даташит
СерияPCM1771
МодельPCM1771RGA
Маломощный стерео ЦАП с соотношением сигнал/шум 98 дБ и усилителем HP (H/W Control) 20-VQFN
Low-Voltage and Low-Power Stereo Audio DAC w/Headphone Amp datasheet
PDF, 980 Кб, Версия: E, Файл опубликован: 29 мар 2007
АЦП азиатских производителей
Pin20
Package TypeRGA
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY250
Маркировка1771
Width (мм)4.2
Length (мм)4.2
Thickness (мм).75
Pitch (мм).5
Max Height (мм)1
Analog Outputs2
АрхитектураMultilevel Delta-Sigma
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ)98 дБ
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP),20VQFN: 18 mm2: 4.2 x 4.2(VQFN) PKG
Разрешение24 Bits
Sampling Rate(Max)48 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1771RGA
