Datasheet Texas Instruments PCM1772PW — Даташит
СерияPCM1772
МодельPCM1772PW
Стерео ЦАП с низким энергопотреблением и соотношением сигнал/шум 98 дБ с линейным выходом (S/W Control) 16-TSSOP от 0 до 70
Low Voltage & Low Power, Stereo Audio DAC with Lineout Amp datasheet
PDF, 976 Кб, Версия: G, Файл опубликован: 26 фев 2007
21 предложений от 21 поставщиков
Микросхема Преобразователь DA, TEXAS INSTRUMENTS PCM1772PW Digital to Analog Converter, 24Bit, 50KSPS, Serial, 1.6V to 3.6V, TSSOP, 16Pins
PCM1772PW
192 ₽
PCM1772PW
224 ₽
Эиком
PCM1772PW
551 ₽
PCM1772PW
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY250
CarrierJEDEC TRAY (10+1)
Маркировка1772
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураMultilevel Delta-Sigma
Control InterfaceSPI
DAC Channels2
DAC SNR(Typ)98 дБ
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP),20VQFN: 18 mm2: 4.2 x 4.2(VQFN) PKG
Разрешение24 Bits
Sampling Rate(Max)48 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1772PW
